Diamond Differential Amplifier
I have upgraded slightly my previous board to single j-fet input.
Config:
-j-fet input (47R/2.2k) around 4mA total
-DD (150R/680R) 5mA
-vas cascode (standard not enhanced) 9mA
-darlington output 150mA
Mile if you can take a close look and tell me which area will need improvement please.
Maybe higher freq thd needs some ??
Can you post schematic with compensations?
The prints from 2 posts back are from amp exacly as bellow. Prapobly tomorrow I will test different setup. With single pair of outputs I will use as simple as possible circuit (if only will pass all tests).
Today another day of hard work.
I have changed config a small bit:
-input stage 220R/2.2k
-DD stage 22R/680R
-VAS compensation 10p each, feedback 33p, drivers 33p.
The clipping issues are gone!! So in next few days I will do the cosmetics on the amp only. The harmonics spectrum is OK (I think). I am missing higher order harmonics --> would be recommended to have a small amount of 4th and 5th harmonics too ?
Bellow results. The previous version SR is on the last scope reading.
-DD stage 22R/680R
Nice results, SR over 20V/us is ok for me.
OnAudio
My learning process is going slowly but forward i think. I have another few amp ideas but I do not know if there will be enough of stamina to build them heh
apexaudio
I have one prototype with TEF atatched to single transistor vas so will try it.
I will prapobly make 2-3 output stages on separate boards to speed up the work 😛
THX
Idea for full symmetrical amplifier...
This design and the design of the first both images of post #7 is basically the same design than those from Ayre (Charles Hansen). Also the french company Cairn-EZO and some other prefer this design, which provides a high open loop gain.
I call this design "mirror symmetry" (my derogative but at the same time true term is error symmetry) or "full true complementary" but both is probably wrong.
Therefore two questions in this matter:
1) which colloquial term for this topology is in the United States usual?
2) what is from your view the audible benefit by listening tests compare to the versions without complementary parts for the LTP and VAS?
This company is unknown for me, can you post schematics?
Heh
If you still have not enough of pictures there you go, bellow TEF version vith single transistor VAS (quick setup on bread board).
I was listening the amp whole day and there is quite big difference between cascode vas version (on the measurements too). This is quick setup made in 15min so prapobly can be improved a bit.
Cacoded version:
-more soft in sound, delicate and bit hidden top octave in compare to TEF version
-bas is more punchy and is lighter than TEF version
-very neutral in sound
TEF one:
-more exposed top octave with sharper edges
-bas has good kick but is hevier than cascode version,
-more ''rock'' sounding amp.
tiefbassuebertr
The amp You have posted is very different to DD stage from sansui.
There is plenty amps using two LTP's as input pair but not many of them are using two floating LTP's as second stage.
