These performance data are much more than conservative... +/- 110 are over than 1.2-1.3 KW @ 4 ohm
because in reality, there are losses (in form of heat) from transformer and from the amplifier device. 😀
Here's the file for BA1200 Protect using NE555 IC....
Hello Sir Wiljj78... I have only 24volts coil supply of my available relay same type with this. Can u help me with what to change in parts for this protect?
Many thanks
Many thanks
Protect from post #28 can work with 24V without any change.
Many thanks sir Mile... 🙂
Best Regards
What is the maximum supply voltage for your version of the 555 timer chip?... I have only 24volts coil supply of my available relay same type with this.........
All my datasheets show Vsupply <= 18Vdc
With transistor add to NE555 out any relay voltage can be use.
Apex,With transistor add to NE555 out any relay voltage can be use.
I do not understand you reply.
Apex,
Supply voltage for NE555 is 5-15V
Protect Files...
Hello Sir Wiljj78.... can you share for the PCB of this not mirrored. I will use for tonner transfer.
Thanks & Regards
Best Regards
Apex, are you expecting Boss to create a new LV supply from his 24Vdc supply, to power the timer chip?Supply voltage for NE555 is 5-15V
Looks like you need to show Boss how.
No, I expect from boss to made descrite circuit (without NE555) with 24V relay.
how much DC will it accept ?
is that adjustable ?
Use DC voltage for protect same as ralay voltage or higher and add resistor in series with relay or use 2 relays in series with double DC voltage.
ahh, no, I meant how much DC on speaker out, before it shuts down ?
about +/-1V
You can use this simple DC protection with 40A relay (12V for car)
hello sir i made this protect but how to test that it is working or not please help me. . .
power supply for SR200 with speaker protection, thermal protection, Temperature controlled fans , transformer soft start , power supply for Sub- woofer crossover
- 1000W Simple PA Amplifier
