If there is enough people interested in this feature, maybe we can give some donation to Domenico, to motivate him to implement this feature in firmware.
Who is interested? What do you say Domenico?
Count me in!
I've already buyed Ian's universal I2S-PCM driver so I'm not anymore..
Anyway I think it is easy to implement and I hope you will get this feature soon.
External power supply
Has anybody used these types of switching power supply for externally powering the Amanero? Any comments?
Nobody gets a "bill" until the minimum of 60 units is added to the GB. So it can take weeks or even months if you are unlucky.....
Nice "try", how do you "presume" I am in such a case ?. Thank you anyways.
@Domenico: I sent you my paypal address as you requested. I look forward to receiving my paypal bill.
best regards,
Pepe
Computers contain a switching power supply already. Isolating with another switch mode makes no sense for me. A linear type regulated power supply (at least one with 7805) can make a difference.
I didn't try yet but If I could able to isolate my amanero with an external psu successfully, I will share my opinions here.
Hello,
I need some help. I've been trying to get my Amanero board to operate in slave mode but I can't get pin '1' to switch to select the clock. Pin '1' is fixed to 3.3V regardless of whether I'm playing music at 44.1Khz or 48.0Khz, pin '11' is fixed at 0V. I've attached three pics of my latest set up. I suspect the board not showing up in Device Manger under Sound, video and game controllers may be the problem. Probably the reason why in Maintenance tool 1.15 the Configuration bits window can't find the board and says no Audio Device found. Any help would be greatly appreciated.
Best regards,
Al
Please see Post#1711
Br
Caad
Configuration bits
I can't get Configuraton bits working. I'm using Slave 2224 CPLD firmware and 1080 CPU firmware. Slave mode works great, but I can't change prescaler ratio and other features. When I click 'Write Flash' I got 'Flash updated' but without any effect...
What I'm doing wrong?
Yes, I've been waiting a long time.Nobody gets a "bill" until the minimum of 60 units is added to the GB. So it can take weeks or even months if you are unlucky.....
Almost there just 31 to go.
Anyone can confirm working of configuration bits?
Domenico, can you help?
Hello !
Is this one : DAC - AMANERO Combo 384 Interface digitale USB 24bit/384khz vers I2s/DSD
is the same one as actual GB ?
ramallo: Check my post #1765
Nobody gets a "bill" until after there is at least 60 boards on order - then amanero will contact us.
This is the way to get the lower price - if you are in a hurry, you can order separate board directly from amanero, but for alot higher price.
- Vendor's Bazaar
- USB to I2S 384Khz - DSD Converter
