Ultrasimple SIT PP amp from BAF , or SIT Beast with a Thousand PSUs
I can do a try….
using the F6 Jensen or the ISKRA (thanks Zen Mod, still best sounding part) or a quadfilar Edcor.
I wrote to Jensen, a week ago to get the choice of Nelson…. no answer.
I have the PSU +-23V
I have tow simple 15V stabilized mini PSUs. Can these two give the bias voltage for left and right channel or do I need four…one for every SIT?
and did I hear right…. 10W at 8 Ohm speakers?
two mini PSUs = you can use them for both channels - if main PSU is also shared between channels ;
in contrary - if making dual mono , logically additional (stacked) PSUs must be separate 😉
of course - each VFet must have own biasing shebang (trimpot , cap yadayada)
regarding power - that slipped from/of my ,already weak , memory
and , yes , even if unobtanium - you know that another pair of Iskras is always available for you
Maybe this will reveal a few questions about $ and scale.
I may lose these to extortion's from a certain Duetschlander guy.
