The inside is nothing special, it's built with Dantimax controls and the Aleph is the Veteran PCB
/Anders
/Anders
nicely done Secanbj.
a lot less spaghetti then i would have thought.
your work is very inspirational to a newbie like me..
thanks for all the kind words 🙂 Now i might dare to show pictures of my Firstwatt F1J
/Anders
/Anders
I would love to see it. BTW, what do you have for speakers. I am interested to know the interaction.
@secanbj.
please show us your F1J.
they can only be better than my aleph 5 mono's also to be found here a couple of pages back.
My F1J
So here is the F1J. Have not yet figured out how to remove the text on the front. The panel on the back i just need to order a new one with the right text!
Connected to these are a pair och BLH with Fostex FE206e
/Anders
/Anders
now that is a good re-use of a krell case.
looks very good.
there are a couple of chemical cleaner that should be able to remove the lettering without coloring the alu. allas, i forgot the names. i will try to find them for you.
looks very good.
Hi-aro....Fantastic!
The first picture is just a piece of Art.... Nice internal design also, a good amp is 80% power supply and 20% amplifier, I guess😀
Do you have more pictures of the front and the panelmeter in it?
What does it show? Output power?
How did you make or where did you buy this wonderful matching frontpanels?
Walter
Walter
@secanbj.
nice, not having the money to buy enclosures myself i use a lot of granite, wood, glass and trespa. i build almost everything from scratch.
but believe me, if i would have enough money i would save myself the time.
I have used paint stripper with successful results to remove the logo on the anodized front panel on one of my amplifier cases; I didn't dare try on the back panel, I used a permanent marker to blank out the text instead.
- Pictures of your diy Pass amplifier
