My_Ref Fremen Edition - Build thread and tutorial
Dario, i was measuring 35 v between lm317 legs. If I measure it between leg of cap and lm317 it shows 35 v on good side and something like 70 vdc on shorted.
Ok, so on 'shorted' board you'll have to replace LM317, possibly transistor,zener and LM318.
On C102/C202 what voltages do you measure?
The 'good' board measure like my pic? If so it's fine and you can try it.
Thank you !
I ll order parts . Probably it has to be ebay or something with low delivery costs .. does anybody know a good source apart mouser ? 🙂
Dario, it would be handy to add measurement tips of how to do it properly in build manual to avoid problems with guys like I am 😀
Just fired up the amps. First try was through dim tester with 60 W bulb. The light became dim after a mild flash. When amps were plugged directly into the wall socket outputs showed 2.8 and 4 mV DC. Now keeping fingers crossed for Ivan to overcome the problems and succeed with the build! Hope to report sound impressions soon.
