VSSA Lateral MosFet Amplifier
Final VSSA weight 137g 🙂. Caps of choice; Panasonic FR and WIMA MKS4. More later ...
VSSA Installation manual - Correction
Hi all VSSA GB members :wave:
By re-reading VSSA Installation manual I found one important thing to be corrected. 😉
In Step 2 of Calibration adjustments the correct text should be as follows:
"Our final target for V-meter 1 reading is 4,00 V and 0 mV for V-meter 2 reading. Turn on the power supply and observe both V-meters displayed values. Clockwise rotation of TR3 will increase V value of V-meter 1 and should have no effect on mV value of V-meter 2 readings. Rotate trimmer TR3 in a direction to reach our final target goal 4,00 V reading on V-meter 1 (meaning 4,00 V/22 Ohm = 182 mA output bias current + front end bias current)."
Please make a note and calibrate output bias according to upper correction. Thanks. :up:
