Retro Amp 50W Single Supply
About the 4QD-TEC
I've used it with single supply. C3 is the output series cap.
I read the text again on the 4QD-, I'll concede C3 is the speaker capacitor. What is not obvious is where the speaker return current goes? Pin 5, 6, 7, 1, 2?
Most of these old speaker capacitor amps like the AX6 generate an internal middle voltage between the plus supply and ground, which can cause assymmetry in the output waveform if that voltage is not really the middle. The speaker typically goes between the middle, DC blocked by the series speaker cap, and the ground. The 4QD may be different, but I really don't understand that point. It does have a middle voltage forced by the power transformer to be the middle, since it has a split supply.
About the 4QD-TEC
Most of these old speaker capacitor amps like the AX6 generate an internal middle voltage between the plus supply and ground, which can cause asymmetry in the output waveform if that voltage is not really the middle. The speaker typically goes between the middle, DC blocked by the series speaker cap, and the ground. The 4QD may be different, but I really don't understand that point. It does have a middle voltage forced by the power transformer to be the middle, since it has a split supply.
assumetry is a given with this amp, as long as you keep the output cap to at least half of your rail, you can maximize output voltage...
in order to do that, i would replace the 220k resistor on the uppermost left hand side to a 470kohm trimpot set to half that value,
this is in order to compensate for transistor to transistor variations,,
hi Mr.Mile,if using Tr 2N3055 RCA for replace 2N3773 can me using 45Vac with 5 Ampere supply?
The RCA factory has been demolished and turned into a shopping mall. Unless your "2n3055 RCA" transistors were removed by you from old power supplies or something, and considering where you live, I would suspect your transistors are counterfeit.
People that have suspect supply sources determine the suitability of power transistors for the application by doing a Vceo test on every one. Since your "45 vac" works out to 67 V peak, make up a test jig to short b to e, put a multimeter milliamps scale from a 70 VDC power supply to collector, ground on emitter, and see how much leakage current you get. Even the 200 ma result from the ST datasheet (purchaser of the RCA logo) is too much leakage to use at this elevated voltage.
We can buy 2n3773 from On semi here, via farnell.com or mouser.com. These have a much more suitable leakage current at 70 v, and a safe operating area spec of 1.5 a @ 100 V, which make a very useful transistor for 70 V supply amps.
