Just one corect, marked cap is 47nF not 47pF.
There you go...
You're welcome...
Some people ask for pcb without PSU, and someone want to put caps 25mm diametar.
Quite nice??? its claiming "here the 2nd harmonic is under -120dB (0.0001%)". Thats 10x less distortion than the Hypex Ncore @2W ....himmm...
Ok, i will make the pcb without PSU like in post#1.
Thanks, use 25mm output caps diametar and 10mm raster.
A little more sophisticated but still retro: 4QD-TEC: Low distortion Audio amplifier
The 4QD-TEC amp has a split power supply and no speaker series cap, so should be used only with a $100 speaker protection circuit, or with disposable speakers. I view the speaker protection circuits everybody quotes on e-bay with the 1 cubic inch disconnect relays as snake oil.A little more sophisticated but still retro: 4QD-TEC: Low distortion Audio amplifier
The advantage of the AX6 was the $5 speaker protection circuit. One part, a series speaker capacitor, tends to fail safe (no sound) instead of fail stupid (toasted speaker coils or torn suspension). I view the whole split supply .0000x% distortion quest as a pilgrimage in search of the unicorn. The lowest distortion speakers I've ever owned are 20 db down on 2nd harmonic distortion 52-14khz @ 1 w 1 m. Amp distortions below .1% are probably totally adequate.
Blowing up those $600 each new $300 each lucky break price speakers with a $100 amp is not on my agenda. Fortunately all my bright flash + odor amp mistakes have been made with a tube amp with output transformers, or the dynakit ST120 with an output cap in series with the speaker. I'm restricting the PV1.3k $55 split supply amp to $5 car radio speakers until I design a protection circuit that will break 22 amps @ 170 volts. The one it was shipped with melts the PWB trace to the crowbar triac instead of tripping the circuit breaker.
AX6 speaker protection wasn't 5$ it's gratis
Try the Kilovac "Bubba"...he wont let you down ;-).
- Retro Amp 50W Single Supply
