My class D amp
H All,
New Simple limiter for AUD600 class D amp +/-72V supply.🙂🙂
Zener 33V for +/-75V Supply.
Low Supply range like
Zener 28V For +/-65V
Zener 22V For +/-55V
Zener 18V For +/-45V
Zener 12V For +/-35V
MANOJ
Hi All,
Good News:
AUD600 Rev3.0 Tested on 18" 4R 1000W RMS SUB WOOFER (Supply Rail +/-75V)
i can't go up to full drive,i can use up to clip indication point. I think AUD600 will give 1400W at full drive may be i need 1500W RMS woofer for full drive.amazing power i am very happy🙂🙂🙂🙂🙂.
BAD News:
My DC protect relay(10A) failed every hour. now i think i need 30A relay for +/-75V supply rail.i burned 6 relays, up to clip indicating point my amp output load comes 10A or more.i suggesting all of you do not use 10A relay more than +/-55V supply rail
MANOJ
Hi All,
Good News:
BAD News:
MANOJ
Hi Manoj:
Wow great news.
what does full drive mean?
Raj
Datasheet for 10A@250VAC relays doesn't have max current rating information for lower AC voltages (like 70VAC @60hz). So to be on the safe side I think 30A@250VAC relay is good for 1kW amplifiers.
Also do not parallel small relays(10A) for class D, because there is a possibility that the relays won't turn on and turn off simultaneously.
When the DC protect is falsely triggered and If the NC pin of relays are connected to ground, and the relays did not turn off simultaneously then the amplifier will be shorted for a very short period < 10ms. Enough for the mosfets to blow if the D amp doesn't have short circuit protect.
DC detection circuit
Hi All:
I am trying to make a DC protection in SPK line using a microcontroller. For sensing DC I would like to use this schematic, will it enough? I will use a 5V zener at input pin of uC for safety,
Please comment.
Raj
