6V6 line preamp
Joined 2011
Its the choke then, what else. Chokes have habits it proves. Stajo, go knock at Lundahl's door next time you are about, and tell them "I got a friend with a wiggle, have you got a remedy?".:D
I can do the underpants grip on him next time, Im about to rip him off some 50 mA 1668s sooner or later. Hey, try some pF-nF caps mr Poros, you might find the resonance.
Ok, here you are.
BW more that 300kHz with resistor load.
Iko, try a square with a #26 with transformer out.....not good!
Anyway, did a draft listen to it, and I think I go with resistor load. Less prone to microphony and sound is almost the same. There was an impression of more resolution with the choke, but I think it was more from the feedback of the tube and choke. With the choke, you could speak next to the tube and hear yourself through the speakers.
Also more space in the box to arrange things better!
