6V6 line preamp
And here I am with perpetual OT. Sorry, George. Just for quick confirmation, are you happy with your scope? BKSabath here would have chosen otherwise if time traveling was invented.
I am happy with the scope, no problems. It does its gob. Also has a primitive signal generator, so you don' t have to buy one immediately. I saw what Sandro said, but I would not recommend a digital one as a first scope.
Hi Stajo,
the ringing is more obvious at lower frequency.
Do you have any ideas what to do? An RC somewhere maybe?
You have to trace it first. Try a fat carbon on the grid is one thing to see if its your signal wire that goes antenna on some freq. For the OPT its usually not ringings in the low Hz area, they are much higher but they can interact on the lower frequencies.
You mean a cap from in to out of the choke and what range of values?
Jones makes a Y split with caps to ground over the choke. Filter chokes almost always rings at some freq but thats not so bad as when the OPT (which is the last filter choke in a way) does it cause you have no more damping after there. You might try with parallell caps from 10 pF up to, I dont know,.. a couple of nF to see if you can see differences.
I calculate that the freq of the ring is between 8333 hz or 10,000Hz. Assuming I read the picture right with 0.2mSec/div. I also think that if it were a signal riding on the output, it would not decay. Could be wrong though. A FFT would be interesting here.
That is what I was thinking. I feel it is a resonance based on the decay, but freq is pretty low. Also note that leading edge of square wave is pretty clean. Would be interesting to see what elimination of cathode bypass cap would bring on the 500Hz square wave
