Tibi, with regard to C66, on the schematic you have it listed as a NPO. Is a silver mica better in this position than the NPO?
Yes, IMHO silver-mica is by far better than NP0.
Tibi
Hi Tibi,
How do you connect the 100nF to the primary side of the transformer? Is it just connect the PIO to the 0V and 220V on the primary AC input of the transformer?
Just place the cap across primary winding.
You need a good quality PIO at 400V. A Russian K40Y-9 is a very good choice here.
Regrads,
Tibi
Tibi, are these meant to be improvements to the existing puck? Is it the same puck, but polished?
It´s polished, but it´s not the same puck.
Tibi
I've decided to go with a separate 8V supply to the main PSB for the transport mechanism and a 5V for the digital audio circuitry on the board. Each supply will be fed by its own transformer. I know there is some debate about whether this will really take things to the next level, but I'm willing to give it a try.
The question I have is, should I do that, or break out a separate supply only for the clock (can I do that?) and keep everything else fed by the main 8VDC PS? I'm wondering if this is a better option. If I go to a Tent Labs clock, would it not be as good if I didn't feed it its own supply, but did have all of the 5V stuff (including the Tent) on a supply separate from the 8V?
You can't leave us with a tease like that! 😱 Tell us about this new one please.
New puck is a little wider and less tall.
Same Aluminium, but better finished.
I got a small review from one customer in A-B test with original Shigaraky. If he will accept I'll post here. I know this is what you want. 😉
Tibi
Ok, I got customer agreement to post here, so here we go.
¨Hi Tibi,
I should mail you earlier but i as trying to ,,improve" the vicol puck. First of all i am very satisfied with the puck When you compare it with the original magnetic puck from Shigaraki The vicol puck has more balance in the sound -more detail- placement of instruments is much better-and more detail. So i,m very happy with it. First i started with only the vilt on the bottem(as on the pictures). Then i start thinking how can i,, improve "the influence of the puck.without destroying it The second goal was if it was not an improvement it should be removable. without damaging the puck.Well it is finished now.The only thing is i cannot make an a/b compare because i have only one puck. 1-On the bottem of the puck is vilt 2-Then the Aluminium of the puck 3-The a thin layer of double sided tape 4-then 3 mm rubber on top of the double sided tape 5-Then a layer of vilt again 6-The most difficult thing is to make the rubber the same size as the puck. 7-the weight of the puck is now from 55 grams to 62 grams. I am more satisfied with the puck now. it is sounding magnificent. ¨
And some pictures.
Tibi
¨Hi Tibi,
And some pictures.
Tibi
Holy crap! What a setup!
But what does this mean with regard to the rest of us and this new puck?
I also have this new puck and I was planning to try something like that because there is a very distinct ringing from the metal while the spindle rotates. I was thinking to put some felt on the bottom side though...
I´m willing to replace old puck for those who want the new one, at the price of shipping.
Tibi
Tibi
You have one old model one as well.
Tibi
Tibi
hi tibi,
that's very nice of you. i'll take you up on the offer. how do i pay for the shipping?
thanks,
johari
cd puck
Hi Tibi,
I will exchamge a old puck for a new one.
Let me know what to do.
regards
Zjaakco
Hi Tibi,
regards
Zjaakco
Please go to vicol audio : Webshop scroll down to last icon. Select shipping up to your location.
Mention in your payment that this is for puck replacement.
As soon you get the new puck, please ship to me the old one.
Tibi
Tibi
Tibi
Tibi, how does your most current version differ from the detailed report on the previous page?
Current version is presented here http://www.diyaudio.com/forums/digi...killer-high-end-transport-13.html#post3416072
Tibi
- Digital Source
- Using the new 2012 Shigaclone to create a killer high end transport
