It's impossible to fool the brain to believe you're somewhere your not.. Digital room-correction is a fine example of that.. you get so tired in your head. You spend so much energy in trying to understand the contradictions that the music looses it's drive and appeal, cause you have resources left to interpret the musical message.
I did not say I liked it, but the effect is bewildering.... It really seems you can emulate room acoustics and space digitally and pour it into your head throu headphones.
I did get me a pair of these HCS 3304 - Programmable DC power supply 1-60V, 0-8A at reichelt elektronik last week, so the investment budget is gone (for now) 🙂
Are they OK for residual noise and turn on spike-less transient? Did you scope the turn on with single shot trigger to see?
I did not do much testing till now, will do next weekend (I think). I did use them as the raw supply to fix a Paradise PSU, and that worked fine. Also, I did some shortcut, sparking, burning and other destructive materials testing with them and they destructed many but still kept on functioning 🙂 They came with individual test reports (I like that).
Manson is a good SMPS HK firm regarding robustness. Do they sport an on the fly on/off over remote PC control without powering down at least? Bcs I see no such function on the panel in your link. How is the fan for noise when drawing some Amps off of them?
It is, as they call it, programable, but that is limited to a remote connected by wire. You can 'program' V, I and on/off by using 5Kohm pots and a switch, there is no PC interface (but I do not think that I need that). There is a schema in the manual, and the connector is included.
OK rather basic interface then, hope they will serve you well. The +/- 60V duals range extends to powerful enough audio amplifiers territory and it will be handy.
Linear Lab PSU 0 - 150V/4A
LAB PSU EA - PS3150-04B - Linear, DC, 1 Kanal 150V/4A, 600W
I Found this one [HiQ Regulation]to be very handy to have at the bench,
two of them for dual supply but the price is the only negative side effect . . .
I've been picking up grunty linear power supplies for my bench work. My latest find was an Instek dual channel supply (2 X 30V, 6A) for ~$200, a bargain. It'll come in handy breaking in Class A monstrosities. My favorite bench supplies come from Topward. I have a couple of their dual 60V/3A models that come in quite useful. My only problem with them is that they use a relay to switch transformer taps in order to limit dissipation on the pass devices - still, not usually a problem.
Higher voltage bench beasts are not popular since general electronics are running on low rails these days. If rather special purpose test gear is needed then it comes at a premium. For circuits like in the MPP thread though, the classic 30V dual isolated output form factor lab PSUs come in many brands and models, and are very versatile. Here is one of the better design and build quality low ripple examples with remote sensing and on the fly on/off output switches. Such should be around the 400 Euro price point VAT inc.
EL-R Series Precision Bench Power Supplies from TTi - laboratory power supply
Good find. Instek are pricey when brand new. Was it in a surplus store or on ebay?
Great Finding,thnx for the info, will begin to save some E... for it. 🙂
Do they have also 2x60V - 4A version this would be best of two worlds also for some heavier works eg. (PAmp)
THNX & Regards
They go up to 56V 1.1A with small singles you can put side by side.
EL561R - AIM-TTI INSTRUMENTS - PSU, 56V 1A | Farnell United Kingdom
A good surplus source for the TTI power supplys (earlier models; factory closeouts) is here:
Test Equipment For Sale
He also sells these on eBay (user name "snibbo"). That's how I found this seller.
I got such a supply from him last spring delivered directly from the manufacturer. You can see it in action here:
http://www.diyaudio.com/forums/grou...oshiba-2sk1530-2sk201-f5x-18.html#post3215268
Any one? http://www.diyaudio.com/forums/chip-amps/227787-opamp-challenge.html#post3325319 did you see this 🙂 or this andre van duin - YouTube 🙂
I ordered this today :PEAK Atlas DCA 75 Pro Halbleiter-Tester | ELV-Elektronik
And if you are out of money Part Ninja v1 free PCB build | Dangerous Prototypes
Found it here EEVblog #413 - Mailbag - YouTube
