Paradise Builders
Hi Frans
He means his caps blew open and are dripping liquid.
The answer to that was the 'no'-part 🙂 (e.g. It does not create 'dripping liquid'). And I do not know how to create 'dripping liquid', besides, mounting the caps polarity reversed, or using a to low a voltage rating, other than that only very bad luck will create two caps with the 'dripping liquid'-syndrome.
little correction, 4 ones. 2 on board "1" in minus stage and 2 ones on board "2" in plus stage. But I will recheck today at home.
Did you check your caps voltage rating ?
yes exactly
Hi Alfred, change input loading to 22K and no changes in servo offset ie +5V so look like i will leave it at that. I will try to find the appropriate material for the faraday cages and re-do the groundings. Thank you so much. BTW is the picture in the build guide is your R3 ? How do you implement input loading switch if you don't mind me asking?
Quan
We need some voltage measurements.
I would visualy check all parts, remove the caps, power on and measure voltages on the empty locations of those caps.
So, I take some measurements:
First of all the power supply is +24,96V and -25,09V. OK or Not OK?
The board with the 2x 6800/10V at V+ broken
VCASCH: 14,4V
VCASCL: -14,4V
V+: +18,00V (trimmed)
V-: -18,00V (trimmed)
V- 4700uF -14,4V
V- 6800uF -5,6V
V+ 4700uF +14,4
V+ 6800uF -4V !!!!!!!!!!!!!!
I think thats it. But why?
Quan
Hi quan,
thanks for the update, thats ok then. Yes that is my R2 build, working as advertised (in fact I had a great evening yesterday, listening to the Cowboy Junkies).
The input resistances in my case are Dale RN65 resistors (stepped 10 / 50 / 100 / 220 / 470 / 1000 Ohm) through a rotaty switch (C&K, with silver contacts). works just fine.....
Hi quan,
Thanks Alfred, can you post a picture how it is implemented if it is not too much trouble?
Quan
