John is on the right way now, and I think that it won't take long until he posts: "Simply beautiful sound".
Best regards - Rudi
P.S.: I love your pictures!
Best regards - Rudi
The other side
Hi After sorting out one side with Rudi s guidance i started on the other side.
No problems works perfectly 36mv with 5 active tt diodes.🙂
The problem i had with r28 smoke stopped when i changed the input short from 2 wires to ground(alum plate) to using a croco clip as in pic .😕. next music
regards john
regards john
regards john
You don't want a DC connection between circuit common and earth/heatsink. It should be connected AC only, via a cap. Something around 1uf will do.
Sheldon
Wow! Horizontal cooling fins. Cool. I mean hot.... and another FC-100, of one of the GERMAN DIYers, working at first go.
The case is still temporary.
Hi Rudi, follow up Post #610.
I wish I could say the New Year started on a happy note, but I'm starting to think this amp only works in Germany ( joking of course).
I measured the Vf's as best I could. The "hot" channel values varied from 430-450mV with the bypass on a 447mV one. The bias is steady at 36-38 mV, the DC offset is low at 1 mV but and the heat sink is hot at 60+C.
However the "cool" channel values were higher (470-490mV) with the bypass on a 470mV one BUT one diode measured low at 386mV. So I bypassed it since I don't know what I'm doing and now the bias on this channel starts at 25-30 and just keeps increasing 35-40-45-50 no sign of leveling off even while tuning back the trim pot, so power off. If I don't bypass that one but another, all is okay bias at 38 mV offset <3 mV and heat sink stays cooler at 45C!!!
This amp seems very touchy. Any ideas?
Happy New Year to all.
Jean
Jean
It work Jean , it work very well, even at Quebec City.....i have two of them.
so i solve my temp tracking problems by changing the NPN output and all goes well. There really a production problem with some of this transistors and it fall on me.
Thanks, Denis. Nice job with your amp.
I know it does work very well despite the differences in temperature between the channels. I'm concerned with stability and I'm just hoping that I don't have to rip one or both sides apart to fix whatever bug is.
Jean: you have to bypass the TT-diode with the highest Vf on each channel!
I labelled the corresponding transistor in the German group-buy; that is why the German builds work right from the start!
Best regards - Rudi
Best regards - Rudi
Franz: Gerhard is a very skilled DIYer; he knows of course that the heatsinks have to be mounted vertically!
The picture only shows a very preliminary build.
Best regards - Rudi
P.S. Dennis: I cannot see your pictures!
Best regards - Rudi
Pictures not opening.
Brian: please attach (using the paper-clip) the pictures to your post. The pictures still won't open.
Rudi
Rudi
Rudi, I know I have to bypass the highest Vf, I was just trying to bypass the "odd" NJL to see if I could resolve the heat differences. Since nothing measurable seems to explain the differences in heat sink temperatures, I guess I will have to line with one side at 45-50C and the other side at 60-65C until something gives! It this okay???
I will look for more NJL's and try to match them like Denis seems to suggest.
2013 is here.
Jean
2013 is here.
Jean
Hi I have now measured my DC offset correctly ,amp on ,,speakers disconnected, left channel .4 and plays music,,,,,but right channel 33.4 volts does not play ,,,what do i look for ? 😕 thanks john
2013 is here.
Jean
Theres many things that can cause this problem.
1- check the current in each branch of the output for be sure that each transistor sink the same current.
2- If not equal, be sure that ALL transistors (output and drivers) are tight on the heatsink, a loose transistor will overheat and will affect the compensation of all others too.
3- Dependly of the heatsink used and the physical location of output transistors on it, you MUST short a thermal track diode at the SAME side of heatsink.
Ex. if you decide to keep 2 diodes on the upper side of the heatsink, you will have a NPN shorted on one side and a PNP shorted on the other side. This is CRITICAL to have the channels compensation working the same on each side because the upper of heatsink is hotter than the base.
- Roender's FC-100 prototype and builder's thread
