USB to I2S 384Khz - DSD Converter
Update for GB3
For all those interested in GB3: I contacted Amenero since the minimum of GB3 was reached some time ago.
Amaneros response:
Hi, i m just waiting the batch of boards shipment from the assembly farm. As for the previous GB, in the week end i'll start the GB sending a PM for paypal invoice.
I hope for Friday to receive the boards.
So, it will hopefully not take long before we will receive the board(s).
Would be nice before X-mas :) :hohoho:
I did a small adapter PCB to conveniently replace the cs8412 in my dac with the amanero for experimental purposes.
The unmounted positions are for a LTC6655.
Note
DSD output enable line to signal an incoming DSD stream.The card supports output mode only.
Sorry for the dummy question, but do you mean that this board converts a DSD stream to USB only, or is it the other way around? I have an ADC board with DSD output. Can this card convert that DSD stream to a USB signal that can be fed to my laptop computer? Is there a master/slave setting on the board? Thanks.
