Studio Reference Amplifier
@Apexaudio
In place of Toshiba-s MJL21193/94 ? I have them home. Allso i have 1000u/100V good elcos, can i use them in place of 470u?
In place of mje350/340 how about C3503/A1381? Much better tr for VAS
MJL21193/94 can be use instead Toshiba-s, 1000uF/100V instead 470uF/100V is OK. No need to change MJE350/340, MJE-s are in cascode with BC550/560. BC550/560 are VAS transistors and MJE350/340 are only voltage translater.
Suggested before
corrected to3 version...
Is it possible to change the solder pads of Q7 and Q8 and make the same size of Q9 solder pads?
Why only 300W when using a FET output stage and +-70Vdc for the supply?
I thought SR200 used 2SC5200 BJT as output, not mosfets,
as you said many times bad SOA at 70V, so guess not much current available into 4R.
I'm sure you could done this on single layer 🙂
+1, Ive tried to do my own pcbs and I must say, I look at Mr Alex_MM pcbs for hints all the time, I've learned so much just from looking at his diy style boards.
Thanks Alex_MM. 🙂
and great contributions from Mr Apexaudio
