UCD 25 watts to 1200 watts using 2 mosfets
An ETD29 core with a 1mm gap in the centre leg only will have an inductance factor (Al) of close to 125nH.
The equation for the total inductance (where N is the number of turns) is N^2 * Al.
So 17 turns will give you roughly 35uH.
If you are adding a 1mm gap to an ungapped core set (so the gap is in all legs), the Al will be much lower of course.
thanks ouroboros
so gap in all legs it will come to how many turns to make 35uh
It is not a parameter that is defined in the data for the cores. This is the time to buy a low cost inductance meter perhaps?
When I get an unknown core, I wind a known number of turns on, measure the inductance and then determine Al. I then can use this value to calculate the mumber of turns needed for any required inductance on that particular core.
  • ucd 25 watts to 1200 watts using 2 mosfets pg 272 Amplificador Classe-D pg 71 lRS4K5 14....10....pdf
to add to the true spirit of diy
here is the inductance meter artwork, schematic and pic hex files have fun all
thanks to systemjol htforum.com
:hot::hot:😀😀
  • Amplificador Classe-D pg 76 lc.zip
schematic of irs3000
Hi andrewlebon
can I get schematic from this amp ?
have only chesthap/triell 3200 1 Ohm schematic
Hi Nmos
greetings no schematic exists just make the pcb and put components there are different variations all work power output depends on mosfet used trying to put dc protection clipping temprature cut off on one pcb
warm regards
andrew lebon
