UCD 25 watts to 1200 watts using 2 mosfets
Hi Andrewlebon,i will try to finish it with in this week,this layout is base on IRS900 with TC4420 used as buffer to drive the high gate capacitance output transistor,i hope this will not affect the self oscillation of the circuit,better to try and stay wonder,cheer's.
Hi exflaco this is base on IRS900,but of course the inverter pin's(CD4049)is different.
how about this core??????
sir, i found this E E core. material........don't know, can i use it with IRS900D?
CORE SELECTION
Hello
greetings which is best suitable core for d class for power output 2kw to 3kw got some sendust cores from china sound has become clearer no heating
of core and fets lukewarm but after some time fets and ir2110 blow up
any reason for this happening for tests i used irfp250 2 pairs supply 70 volts dc+/- any clue why this is happening
warm regards
andrew lebon
