Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Hi Dimitris
Thanks for sharing your code, it save me lot of time. I modified the code to fully utilize the screen, interface with Ian's FIFO and Selection mode can works with Remote. The only thing that need to be added at the moment is the controlling of Sidecar for selection between SPDIF and DSD.
Very nice!
Controlling the SideCar should be a piece of cake, considering that the input selection code already exists and that the sidecar itself is essentialy just a relay.
I still can't convert a jpg file and display it on the GLCD successfully. I managed to display 3/4 TPA logo. Most of the time get the error message "image file too large" when compile the program. Can anyone help?
I am guessing that you are using the myGLCD.drawBitmap function and Henning's online ImageConverter 565.
Are you sure that the c files that are generated are not too big?
For example, the little graphic displayed below takes up almost 20K of memory:
attachment.php
Very nice!
I am still considering whether use SideCar or not as it is not a good device to switch high frequency digital signal. I was thinking to use Ian's BIII input adaptor with SideCar for impedance matching but seems not that simple.
Hi Dimitris
Did you buy the available shield with the screen?
What is the pin layout you have used for the screen & mega?
Do you have a link to the code you are using?
Yes, I bought the shield with the screen, it made wiring much easier.
You can directly plug the screen with shield onto the mega. If you want to connect them by wires, just download the two pages manual.
PM your email and I will send you my code.
attachment.php
I convert the TPA logo using the online converter and the file generated is 20K which cause the "file too big" error.
That is indeed odd. I don't have much experience with the drawBitmap function, but since it stores the bitmap in an array, it is limited by the max size of an array.
If I were you, I would probably experiment with the UTFT_tinyFAT library and try storing my bitmaps as files on an SD card. That is probably the way to go in the long run, since the 256K available on the MEGA is pretty limiting.
Thanks for your suggestion and will try this weekend.
It might not all be bad news,
If regulators don't light up you either have a short circuit or power was somehow disconnected.
Seems to me short circuit more probable because all regulators are off, try unplugging the adapter and power up again.
Hi CeeVee
you are correct, it was caused by short circuit. I hoped it was caused by something else other than the ES9018. After I removed all the tridents, DVCC and GND on the BIII still shorted. The only component connected to these points is the ES9018. I further confirmed the chip is dead by removed it from the PCB. No short on PCB and the two pins on the chip shorted.:(
Yesterday, tried to connect FIFO and BIII using Ian's adaptors. When I power up BIII, all LED on tridents not "On". Although I immediately switch off the power, still could not prevent the disaster. The ES9018 on BIII dead.
That's too bad. Seems you are capable of replacing the chip yourself.
I was enjoying reading about your project very much...
Joined 2006
Thanks glt.
I've ordered the chip from China and it cost $40. Hope I can fix it.
Have you found reason for short circuit yet ? I'd like to see you conclude your project....I'm working on similar one and was hoping to use your code...I'm no good there ;)
It would be indeed sad if you put a new chip in and the root of the problem is still there....boom another chip gone !
I've ordered the chip and hope it will arrive in the next couple of days. I don't know what actually cause the chip die but may be the I2C bus shorted to the SSLV supply rail when I accidentially drop the I2C level converter onto the SSLV when I was testing the BIII with Ian's adaptors.
It would be nice if you could share some photos of your repair experience
