Melon Head's State of the "DUMB" Open Baffle Design
I was thinking the 12.2 alone on Phy. Gues i did not realize its limitations. I am lookig at the Delta ProA 15" to go with aN15. Guess i could go ahead and get them in anticipation. MY 12.2 have been sitting here for 3 weeks untouched. Now Melon is screwing with my head again with his top secret,secret. I think he is losing it from lack of sleep😀
How does this look?
Fs=32Hz
Qts=0.4
97dB/W
With smooth frequency response. No notch required
No resonance peaks
I can't give any recommendation based on sound quality yet because I have not heard them. But I am thinking of purchasing some.
If you can wait then I can tell you how they sound when they arrive
I use the MCM woofers all the time. You cant beat 'em. There's also quantity pricing on 4 or more and promo codes to save an additional 15%. They are a nice, well made cast frame driver. I have 6 of the 10's right now. I've heard the 15 and it sounds very good on the low end... very little mid that rolls off nicely and naturally.
I am thinking of getting 8 of the 10s and 4 of the 15s
you'd be suprised.........I prefered a foam box around the backside of the driver, my wife didn't.
my wife wouldn't like having a foam box around her backside when she's driving either 😀
I had intended to send you a PM about possible matches for the 12.2 in an OB. 93dB area looks prime if I uses doubles per side. I didnt want to spend too much money, as my final goals is the AN15. Any other suggestions and which of thew ones you tested performed the best?
it sounds as if you have given up hope that the 12.2's will be good enough ? - I have been looking at those drivers, I thought that on paper at least, they look really good and might offer some benefits over the AN15. The Alpair's are without whizzers for starters and their cones appear more refined, plus size-wize they look to be more flexible for enclosure options.
I have to go and cut wood now.
Time to build this 5.6 cabinet
excellent, I'm looking forward to hearing what you find. I may pick up some plywood sheets tomorrow (if it's not raining as they will stick out of the back of my car).
Not at all. I think most folks would be surprised if they heard the MA drivers. I am actually quite excited, as Dave and others say they image as well as the 7.3's. We will see. The 7.3's are addictive. Listen to them for a while, and all of the sudden, everything else sounds cloudy. MArk is the only person I know talking about microresonances. I wish he would do a big Alnico verson. Oh well. I know the paper 12.2 probably will not have the level of clarity of the 7.3's, but the dynamics should improve. May just out them in an OB tomorrow and have a listen crossed with my WoofEE.
I wouldn't buy woofers from mcm. My friend here at work got some 12's and had someone measure them. The qts was supposed to be around .4, instead it was over 1. He's upset because they are useless except for open baffle.
So don't trust their specs.............
Norman
Norman
I am happy to be the guinea pig and measure them.
Looking at the size of the magnet I don't think they could be that bad. Maybe Qts around 0.6 to 0.7 but not higher
