UCD 25 watts to 1200 watts using 2 mosfets
Thienchay,
Do yuo also have DIY files for the 12v bias regulator of IRS900D?...
thanks!
Yeah , i used LM317 for 1 Channel .
This my Layout and PDF file 🙂
  • IRS-2000D 2 with LM317 regulator _ PCB.pdf
  • IRS-2000D 2 with LM317 regulator _ Overlay.pdf
does dead time vary with voltage ? as in the more high voltage you use the more you have to adjust dead time.? 😕 😕 and how cn one adjust ??
Digital deadtime no,but effective analog deadtime may vary somewhat with this schematic ,you have to measure with the scope.
But with increased voltage , switching disipasion increases also , and you should adjust deadtime at maximum used voltage for lowest THD possible and maneable disipation.
Hi
+ (12V) on Regulator Board connect to +12V on Power board
.... and - (GND) on Regulator Board connect to COM (V-) on Power Board .
GND of Regulator must be connect to V- on Power Board .
thanks,,,Thienchay
its negative referred....i have etch the pcb of the design which u provided...can u tell me the value of the resistor RSS and osc and also RFB....i need to know the inductance of output coil
thanks,,,Thienchay
Yeah .
- RSS dependent of rail voltage you used , you can calculate it , RSS = (Volt - V(zener) / 0,01 (set 10mA passing RSS) .
+ EX : If you used +/- 75V ; RSS = (75 - 5,6) / 0,01 = 6940 , so you should used 6,8K ohm / 2W 🙂
- RFB = 100K , OSC = 1K , it set Gain .
- OCP = (V bias x R ocp / 6800 ) / R (Source MOSFET) . Set limit of output current .
+ EX : I used 12V Bias , R ocp = 220 ohm , R (Source) = 0,02 ohm ( 5 x 0,1 ohm parallel)
(12 x 220 / 6800) / 0,02 = 19,4 Ampe 🙂
Change R ocp is change limit output current .
- L output ~ 30 - 40 uH .
Hi Thienchay,what output mosfet can i use for +/-80V ? i was thinking at IRFB5620 (25nC gate charge) because they are class d mosfets and they are easy to drive at high speed without overheating the driver IR2110.I build a CHE900 and with IRFP4227 and 1k at oscilator i had 500Khz oscilation but the IR2110 was very hot 60-65 degrees,so i change the R OSC at 470R and got exactly 300Khz IR2110 only 40 degrees but the sound on high's was a little under the veil like something was missing.
ionutzxpo, is this the ROSC that you're talking about?
