Pictures of your diy Pass amplifier
Joined 2011
-2x30v switching PSU from a linn music system (doesn't sag at all, doesn't run hot)
-DIY PCB's, as small as possible. the way i always make PCB's ;)
(i've committed a small grounding sin in this picture, but there was no hum so i left it like that for the testrun)
and it sounds lovely. i will run the final casing with some slow and silent fans because this heatsink isn't up to the task for normal use. for short tests it's just enough.
hi i am building my aleph 30
it is said this amp no need adjustment.
in my amp the dc at speaker out is 0 to 5mv on left, but always -22mv on right.
how to balance both amp?
thanks.
Hi, got a pair of that pcb once on my desk, I think you'll have to change R11 to 1k multi turn trimpot, may be paralleled with 400R, good luck
