Box colourations - really ?
I have never seen anything that measures with better absorption than acoustical grade fiberglass and its near equivalent, rock wool. When architectural acousticians need a material that works (effectively absorbs sound in a classroom, shopping mall, office building, public building) that is what they use.
Plus they are as near as your local Home Depot.
And for those of us allergic to glass wool / fiberglass ? 🙁
Also what is the likelihood of glass fibres or dust escaping through a bass reflex port into the room ?
I'm not seeing the point of the 2D QRD type internal diffusers shown earlier, if you use stuffing as well. All I have read on the subject suggests that when covered, diffusers don't behave like diffusers any more.
Otherwise I agree with speakerdave in his post a couple up about internal absorption. Tallies well with my experience too.
Since most of this discussion seems to be centered on the absorption of internal cabinet reflections or standing waves, let me give you guys some ideas to think about. I've attached a couple of graphs showing absorption quality vs. material thickness. These are for some high quality foam absorbers and the usual rock wool and fiberglass.
As you can seen material thickness is key for a low absorber cuttoff. Every time you double absorber thickness you achieve an extra Octave better performance. We might just put a 2" material lining around the inside of our cabinet and see that anything above the 500 to 800 Hz range is over 90% absorbed. Is that good enough?
It turns out that we need to absorb down to the 1/2 wavelength of the longest dimension. A closed box will have 1/2 (and 3/2 and 5/2) wave resonances for every dimension (LWD) so the most difficult one to absorb is the 1/2 wave of the longest dimension. If we are thinking about a 40 inch tall tower cabinet it would resonate at about 170Hz. Looking at these graphs I can see that about 200mm or 8 inches of these materials would be required.
That turns out to be about 1/5th of the cabinet height. In fact, for any cabinet length or height that we can think of, as the cabinet gets longer the depth of treatment will also grow exactly in proportion, so we can simply state that an end of cabinet depth of treatment of 1/4 to 1/5 the wavelength of the particular dimension will always be needed but will also always be sufficient.
It also turns out that less material will suffice if it is spaced off the boundary. Architectural acousticians know this and save money by spacing absorbers off of the wall and ceiling. Many architectural materials will give data for "E400" mounting. This is the absorption quality of a material spaced 400 mm above a hard surface, which is the average spacing for a drop ceiling below a true ceiling. Such measurements are usually pretty close to having the qualities of the full 400 mm of material but at a considerable cost savings. So our 50 or 100mm material might work pretty well if we space it 1/4 wavelength off of the bottom or back wall (always 1/2 way down the cabinet).
I'm talking about real absorptive materials such as Rock Wool and Fiberglass, not BAF or Dacron pillow stuffing that have near zero absorption.
In the end it isn't hard to absorb the internal acoustical waves in a speaker cabinet if we use the right materials and take care. Airborne and structural born cabinet vibrations are another matter and perhaps we should be concentrating on them more as they are more likely to cause cabinet colouration.
David S.
What about building in some internal baffles to effectively break up the resonant spaces into smaller spaces?
Assuming you will put the woofer in the top of your cabinet as drawn, I think you are still in the same boat. The divided spaces you create will be resonant in the frequency range wher your damping is already very effective. The issue is effectively treating the lowest modes and you will still have a mode due to the longest path from top to bottom. It may be a little longer/lower with the zig zag path of your labyrinth, but that only makes the treatment situation slightly worse.
David
This is very interesting stuff David. As always, you have provided real sources of practical information that we can use in our projects.
Can you elaborate on airborne and structural born cabinet colorations? Are you talking about bracing? This is an interesting topic for me right now because I'm trying to kill a vibrating back panel on a vented box for a 15" woofer. The box is about 6 litres and the back panel is 26" away from the front, resulting in a 260 Hz wrinkle in the impedance plot.
David
Um, I actually don't have the woofer at the top - does it look upside down to you?
My understanding is that resonances require two unimpeded parallel surfaces. With the intermediate baffles, yes each will form a smaller resonant space, but the longest path would be without these requirements.
Reflections would still mostly be diminished with the top and bottom absorption material you would have already used, with only the middle space now needing it.
You're definitely right, it would have problems - I'm just wondering if they would be less or more problems than without.
It would be an interesting thing to try, IMO.
Thanks for the comment.
We talked about cabinet construction with regard to resonances, structural rigidity etc. quite a bit in this thread:
http://www.diyaudio.com/forums/multi-way/138111-what-characteristics-better-material-enclosure.html
You'll have to seperate the fact from fiction, though.
15" woofer in a 6 liter box sounds pretty snug (maybe 6 cubic feet?). Bracing or a front to back brace will certainly raise the primary panel resonances of the front and back panels. I'm guessing that if you have a resonance strong enough to see in the impedance curve it is a combinational resonance of front and back panel resonances and woofer mass. Bracing the back of the woofer magnet structure to the rear panel may help there.
My preference is always to go for damping rather than just stiffness. Damped decoupled masses such as ceramic tiles with a lossy glue coupling could be a good approach too.
Woofer decoupling might be a big help also. The first decoupled woofers we did at KEF where to improve a similar big resonance that the 12" woofer (B300) of the original Reference 105 had. The 105 mkII had the trochoidal woofer chassis and decoupling, and it dropped cabinet vibration quite a bit.
Good luck with that.
David S
Hey, whats more important, being able to breath or having good sound!
Most people are okay using plastic gloves for installation. If not there are some acoustical foams out there that are good. They tend to be more expensive so I've never pursued them.
Fiberglass out the port is a real factor but it diminishes over time as the loose stuff blows out. Cutting the material cleanly will reduce the problem. You can also line the cabinet and then cover that with cheesecloth (or just about any cloth). Some systems have used squares of fiberglass, each nicely wrapped.
David
Two reasons: a possible slight high frequency reflection that is improved by allowing the sound to bounce off the surfaces and down into the wedges, and it cuts the required material in half.
I think the first factor has much to do with varnished or covered surfaces used for wedge durability.
It means nothing to us in loudspeakers because we don't have high frequency issues internal to the cabinet (2 way crossovers keep HF out of the woofer enclosure, plus woofers are a good HF barrier).
Yeah, good point.
I have actually measured the reflected energy off different types of acoustic tiles, done in a large near-anechoic room. At frequencies above 1 kHz some of the so-called acoustic tiles dont work at all. Pure fiberglass is excellent though, reflection is below -30 dB at 1 meter distance. That will however mean, that at 10 cm distance the reflection will still be significant.
David S
Thanks for the suggestions! Yes, it's 6 ft3, not 6 litres 😱
I had considered sewing acoustically transparent grille cloth into covers for rock wool or fiberglass to cut back on loose glass fluff. For inside speaker enclosures, or frameless absorption panels in a room (hang from ceiling/wall with the eyelets like tarps have). You can buy the eyelets and an eyelet tool from Home Depot 🙂
Yeah, good point.
Its true that fiberglass has high absorption but not infinite absorption. I went with an acoustician to a court room with a large perfect dome ceiling that you could stand in the center of. It had been lined with 1" thick high NRC fiberglass. Still had a pretty audible bounce back (the acoustician said "you should have heard it before!").
A 30dB reduction would be 0.1% return, in energy terms, or 99.9% absorption. Thats pretty good. What we are really looking for is a reduction in the standing waves internal to the box. Diaphragm mass also contributes attenuation through the woofer, so if some energy reflects from the cabinet walls it will still be further knocked down by going through the woofer.
David S.
Gary Pimm research has him advocating UltraTouch recycled cotton insulation even better. Pricier thou. And available at Home Despot in the US.
We use it instead of fiberglass, and are starting to expeiment with it as a sub for pluff in TLs.
dave
Blonded Logic Ultratouch is better at lower frequencies than same thickness of fiberglass, and it's a pleasure to work with:
http://www.bobgolds.com/AbsorptionCoefficients.htm
When we talk of resonances..The three differing enclosures, sealed, ported, OB, each have there own battle with resonances. IMHO the ported being the most difficult. Consider the empty wine bottle...try this easy experiment, whistle into the neck...the Fb is apparent, but you can feel thru the bottle the vibration at that F ....The Fb has set the bottle in motion, & this motion will make its "own" sound. This probably why the tone is not a pure tone, like the tuning fork. All the non-linearities & harmonics will be created. My take on this is, if you can feel vibrations with your fingers on the enclosure...it ain't right, accurate....FAIL.
Long ago I did the simple experiment with the so-called fibreglas damping stuff, putting a wad of the stuff to my ear.....no attenuation..next, try it with some cotton batting...now we have attenuation. At the microscopic level, all we have is a random forest of solid glass "trees"....I think 'they' are trying to do the inverse square thing, hoping the sound will bounce around enough to attenuate.....next we have a "forest" of "trees" resembling giant ropes....which do you think will work best?
I for one would be hard pressed to build an enclosure at six cubic feet, ported that wouldn't vibrate at Fb...I'd start at two inches thick MDF, glued & pressed.....& keep making it thicker till no vibration is detectable. Using un-common materials is an option, but I've found MDF to be very "workable".
__________________________________________________________Rick...
