hi can it take 75volt?
i already have a toroid i would like to use.
No problem.It can use the +-75V
Happy new (chinese) Year ljm
Laugh.
Is done and leave for some time. The work is very busy, as well as there is no time to DIY and to forums.
Was too busy
I have a chassis with preamp and a PSU of +-DC 53V . I have only to decide for the power amplifier and protection circuitry.
What provides better sound, an Class A / B amplifier as the L7 or a classe D as the L15D?
If you prefer the class D, which is the difference between modules and the module L15DX2 L15D (other than being double)? Why the larger size of the L15DX2 caps ? Which is better?
L15D for active 2-way?
I’ve been lurking this and the L20D thread for some time and have a few questions about the boards. I’m building an active 2-way bookshelf speaker with a full range driver and a bass woofer where I plan to use the 2 x L15D boards + 1 x SMPS inside each speaker. The full range driver is 8 ohm 20W and the is woofer 4 ohm 150/300W (nominal/peak). For power supply I’m planning to use the SMPS300RE +-45V.
- Will the speaker drivers’ impedance difference be a problem for the L15D boards + SMPS300RE?
- Although the SMPS300RE is not taking advantage of the L15D’s full potential (as opposed to e.g. the SMPS500R), will this SMPS be sufficient considering the speaker drivers I’m using?
- Is the heat generated from the boards so high that I need to vent the speaker enclosure or even place external heat sinks?
L15DX2 higher than the L15D performance difference is not particularly large.
Distortion smaller.
Analog amplifier L7, its wide range of applications. No fixed rules on the voltage.
Are free to use, L7, very durable
Thanks for the advice.
It should use the L15D + - 45V DC power supply.
The L15D the fever is lower than the L20D 25D. He can be full of power without the need to increase the radiator.
So is there anyway to BRIDGE two of these modules? and what would the power rating be?
Recommended to use this.
Its circuit by IRAUDAMP7S.
It can achieve 500W power 8 OHM
ljm_ljm,
With the heat sink vertical on the board it doesn't look like convective airflow over the fins will be very good, since the board underneath blocks it.
Do you know what is the maximum average power that a module can dissipate when in a closed box?
And how much if the box has ventilation holes above the heat sink?
Also , what are the dimensions of the board? I searched but didn't find them, and the ebay vendors don't give them either.
Marked on the front of the reference map detailed size chart I can find.
L15D fever is relatively small in actual use, almost no temperature.
According to the datasheet of the original IRAUDAMP7s has multiple protection features that have not been included in LJM designs.
Anyone know if its necessary in original (or ebay copy ) IRAUDAMP7s amp add another protection circuit as a delay for anti-plop or similar?
[FONT=仿宋_GB2312]
[/FONT]
- Over-current protection (OCP),
- high side and low side MOSFET
- Over-voltage protection (OVP),
- Under-voltage protection (UVP),
- DC-protection (DCP),
- Over-temperature protection (OTP)
Cristi's latest IRS2092 designs are supposed to include multiple protections.According to the datasheet of the original IRAUDAMP7s has multiple protection features that have not been included in LJM designs.
Connexelectronic CxD400
Connexelectronic CxD300
The detailed description is not yet on the website.
Speaker protection board, including anti-pop delay are easy to find on ebay.
In fact I have a design similar products.
But after testing his performance is not the L15D good, so I gave up.
I repeated the same reference design based on the IRAUDAMP7S.
But every time the failure of the test in all SMT less than the performance of L15D.
400K HZ PWM frequency. Inductors, capacitors, filters.
Waveform distortion. L15D DIP parts. Distortion is very small.
At present, I still have no way to using SMT instead of DIP.L15D version.
- Vendor's Bazaar
- LJM Audio
