That is one gorgeous chassis! I am glad to see somebody else is stacking torroids!
I am only lifting them!😀
here is the drawings of my latest toy
An ancient robot with a new alkaline battery...
[b]MOSFET again[/b]
Design by Federmann
Design by Federmann
Here is a mono power amp board I designed a few years ago, depending upon outpet devices and power supply voltage rails, it will deliver up to 200W into 8 ohms with very little distortion.
APEX D14
Are those boards the same? I ask this because I am not sure, but it looks like on one board the output transistors are one way and on the other board is different.😕
Maybe he didn't fire it up yet... Outch!
Hi there all
Theres some fantastic looking amps in this thread, my next project after ive finished my DAC will be a big amp. (im only a newbie)
This was my first project i ever did, a half assembled Velleman K4020 kit i had given a month back.
Regards James
Regards James
TO-3 SymAsym
I had an extra set of SymAsym boards and I decided to use them to rebuild an old amplifier. The layout is a bit unfortunate, but workable. Since the heatsink assembly was made for TO-3 transistors, I chose to use a set of 2ST2121/5949 outputs. The amplifier is unconditionally stable and has a 450kHz bandwidth.
Here we are, work in progress.
-Henry
-Henry
- Post your Solid State pics here
