only one hot is filter caps 1uf, huh.... so im worried it will explode if play long, so i reduce it back to 250 khz, why that caps hot?
Surely bad cap , to bad.
Dimonis :
my amplifier THD and IMD lower...but since no one makes those tests
Maybe you'll paste some measurement THD+N of your amp?
Which programm is suitable for this ?
I have Spectra Plus 5.0 , but didn't try it .
I am using RightMark Audio Analyzer 6.2.3(free version) and Acoustic Analyzing System 5E(THD only), they give similar results.
Some measurements:
Some measurements:
Dimonis :
They require kwatts and full audio band...personally i am interested in getting my amplifier THD and IMD lower...but since no one makes those tests i have no help in this matter.
norazmi:
What residual amplitude do you have?
cpx , ive download the program u told me, and i need time to learn coz too many setting and option, ill try to learn it as fast as i can. Btw what exactly cause filter caps become hot? Too high freq?
norazmi:
To much esr...and too much disipation when testing with high voltage and high frequency output, with no input signal and normal oscilation you shoud have no heating.
To use that software you need to make an output divider and filter.I made some very aproximative calculations... but i hope it helps.
Hi All
CPX you are doing a wrong method
Desktop computer already have noise(More compare with Laptop) , so how you measure THD+N????
Please show your right method
Noise have all equipment , best audiocards for desktop comps have about 0,001% THD+N , don't think that you diyamp is somethink equal.
Only bad quality caps ,never had such problem , maybe smth wrong with the inductor?Btw what exactly cause filter caps become hot? Too high freq?
What amplitude of ocsil.frequency is at output ? And what frequency?
What about the winding? How much turns?inductor is T106-2, idk in real life because i dont have osc, in simulation its normal, output freq 500Khz before inductor. i`ll try change filter caps maybe its broken or bad.
To bad without oscil , you can't realy confirm that it's 500kHz .
Simulation is good , but the practical realisation differ a lot.
yup ur right Dimonis, i do measure with amprobe freq meter in real life. and i have inductor meter too, measure it 30 uh. I`ll try to find out and try to change with another filter caps. inductor remain cool, that filter caps hot when play loud, and at idle it remain cool. Trying to google too maybe i can find out what may cause the filter caps heat.
i`ve found this something interesting: by John Widder and Yun Tao Zhao, STMicroelectronics.
Class D amplifiers generally use a low-pass filter to attenuate the switching noise in the output waveform while passing the audio signal to the loudspeaker, but many engineers are not familiar with the functions performed by the various components in a Class-D amplifier filter or how to calculate the proper values. This article explains the purpose of the filter components and how to calculate their values.
The heart of a Class-D amplifier filter is a L-C low-pass filter. The corner frequency of the filter is chosen so that the filter will have minimal effect on the desired output frequency range while attenuating the switching noise as much as possible.
Low-Pass Filter
The optimum value for the filter inductor is
L = RL/2πfC
where fC is the desired corner frequency of the filter and RL is the load (speaker) resistance. Note that the inductor value is dependent on both the desired corner frequency and the speaker impedance so the inductor value will changes if the speaker impedance changes.
Practical designs require the use of standard component values so small adjustments usually have to be made to the ideal inductor and capacitor values. Rather than calculating the inductor and capacitor values independently and then adjusting their values, it's better to calculate the inductor value, select the closest standard inductance value, and then calculate the required capacitance using the selected inductor.
C = 1/((2πfC)2 • L)
The quality factor (Q) of a filter is the ratio of the center frequency to the filter bandwidth.
Q = RL√(C/2L)
A high Q produces an underdamped curve and a low Q produces an overdamped curve. The Q of the filter should be in the range 0.6 > Q > 0.8 to avoid underdamped or overdamped behavior. If you use the equations above the filter should have a Q of about 0.7, which provides good performance and allows for impedance variation in the speakers. Note that the Q of the filter will change if the speaker impedance is changed without adjusting the filter component values, which can result in an underdamped or overdamped response.
Component Selection
Not only is it important to choose the correct L-C filter values, it is also important to choose the correct types of components for the class-D amplifier in order to avoid losses and minimize harmonic distortion.
The DC current rating of filter inductors must be greater than or equal to the maximum current that it will see. The change in inductance versus load current should not be more than 10%. The core material can affect the amplifier's harmonic distortion and should have very low hysteresis losses.
The capacitor should be a multilayer polyester, polypropylene or polycarbonate film capacitor. Avoid using ceramic capacitors in the low-pass filter. Ceramic capacitors experience large changes in capacitance as the voltage across them changes, which can result in distortion.
Low-Pass Filter
L = RL/2πfC
C = 1/((2πfC)2 • L)
Q = RL√(C/2L)
Component Selection
Domonis can i ask is it possible to replace 74HC00 to 74AC00 do they have same pin configuration, any parts to be replace?
does ir2110/2113 can drive 4 irf4227
1.Yes they have the same layout , the 74AC... serial is prefered , it's faster.
2. It depends on the working frequency of the amp , if above 250-300kHz - only one! If you try to drive more , the ir2110 will just simply overheat.
Look at the curve (it's from datasheet of the 2110)
It's not for 4227 , but find some approximately matching.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
