diyAB Amp - The "Honey Badger"
This is the DA prototype build which has been tortured for the past 2 months. It only runs at about ~60mA per device since my converted bench top power supply has a limited headroom. It shall be retrofitted with a monstrous power supply and push the bias to OS's recommended upper limit. Also, the inclusion of a soft start circuit and a speaker turn-on delay and dc protection circuit.
J
running the "big" ccs of the VAS at ~11mA and I get a stable 56-57*C temp on the small heatsink for Q10, Q11, and Q12.
trying the "finger" test and it kinda stings if I try to touch it for 5 seconds. kinda hot for my taste.
planning to reduce ccs current to about 8mA. any experience in running devices this hot for prolonged periods? I'm just worried about the device longevity or do I just worry too much?
if you have a distortion meter, you can measure the effect of lowering CCS current to 8mA, i feel there is no harm in that....
AKN
Joined 2005
I think OS choose high VAS current because of the 2ef topology. In order to the keep distorsion low into low impedances he wanted high VAS current. I recall he mentioned this somewhere earlier in this thread.
Measure distorsion into severeal different impedances with high and low VAS current. Differences?
Why not increase cooling instead?
the Ampzilla's used TO-66 devices, not sure if still available, on bigger heatsinks, that is why they can operate that way...
Yup I remember they used TO-66 devices, not to mention some devices that are "proprietary" GAS devices.
And most of all, I remember it to really, really sound great like the DA Class AB prototype.
how is the sound compared to say a leach?
As I have Prof. Leach's Low TIM version, I think I would say that the Honey Badger (that's our nickname for it at DA Central) has more control of the lows and is somewhat extended in the highs but not that tiring (I didn't even used the lead compensation cap).
The Low TIM is a great amp, excellent numbers during measurement. My only qualm with it is it doesn't seem to go low enough, don't get it wrong though, it's capable of a lot of bass but it kinda rolls off quite too early for my ears.
Imho, the Honey Badger is in it's class, a well balanced amp, it behaves well even with low impedance loads and performs right as intended. Overall sonic presentation is excellent. Any amp builder, diyer, amp collector, student and what have you will surely enjoy building this and be rewarded afterwards by being able to listen to a wonderful amp that can give commercial amps costing many times more a run for their money.
Cheers
