My Transistors, original or copy?
This one measures as a genuine 2SK170BL and it doesn't have cowboy legs.
The pirates and thieves are out there to get us poor mortals.
Can we not help ourselves by trying to design using CURRENT and COMMONLY AVAILABLE parts.
All PIRATING is driven by a shortage of supply or the COST of RARE components.
Surely semiconductor manufacturers are trying to improve their products.
There MUST be a commonly available alternative to most devices - ICs maybe not, but discretes I would say there must be.
The 2SK170BL and the 2SJ109 have become almost unobtainable. We are inviting the counterfeiters to see us off by still ordering them.
The last few threads on counterfeit devices have been so obvious its comical. Unfortunately you wont know until you receive them. These devices have been so clearly sanded (abraded) of their original part number that a 6 year old could spot them.
That is not a slur against us, we are only buying them. If we dont buy them, the counterfeiters will go out of business.
the problem with using modern devices, is that existing circuits may need to be tweaked to use the modern components. if i use more modern output transistors in place of obsolete ones, it's likely i need to recalculate the original compensation caps to keep the amp stable when using transistors that have a different Miller capacitance. it's not a difficult change, but it's one few are aware of, and the difference in Miller capacitance can make an amp oscillate.
however, we should be paying attention to companies like Fairchild and ON that are licensees of obsolete processes, tooling, and part numbers, as discontinued transistors are often added to these two company's repertiore. also, using reputable distributors, rather than buying from "E-Slay", or from what we used to call "phone booth" brokers, would alleviate a lot of the trouble. and as the old saying goes, "if you think it's too good to be true, it probably isn't".... stop jumping at the chance to get 2SC5200/A1943 devices for $2.00 each.
Im intigued as to what my Fake 2SK170BL actually are.
At a pure guess they are 2SK170GR - what is the best way to measure these devices for passive parameters ?
I've got a MM that can measure capacitance. I don't want to go to too much bother in testing them, but if they are 2SK170s I might still be able to use them.
