Isobaric - less then $20
Hornresp is not aware of the effect of the stuffing to be used in the T-TQWT and so cannot accurately simulate it. It appears that b🙂 has to manually process loads of data outside of the MJK worksheets to account for all the variables included in his efforts.
I haven't put "the pedal to the metal" yet on one of his other designs, but I built it to spec and did a very light sound test and it sounded great. I will be putting the finishing touches on the other T-TQWT project within the next week or two and I am really looking forward to starting this smaller one!
I had a look an that thread, I feel famous there are so many pdf's with my handle on them...
I've been playing in the wood shop😀
I thought you had enough speakers? Are you going to add damping material?
May do some more stump grinding for the two top corners shown. So if I was going to set upright...I'm thinking 3" blocks?
___________________________________________________________
Pinkley: "Very pretty, General. Very pretty, But can they fight?" The Dirty Dozen 1967
Hi ODougbo,
That looks interesting. Just some little corners as you have them at S1 would be fine, the wavelength of interest are just way too long. As to the height, you may have to play with that a little, 3" to 4" should be sufficient.
Any details on your project?... the woofer look serious, though not a woofer that I recognize...
The design is top secret as you can see 😉 <270l @ ~30Hz, fairly beefy 15". I'd be pretty bummed if you did recognize this driver, though I do think this basket will gain popularity quickly.
I do - can't you see😛
😱probably not it's a TH, I don't have a way to calculate the effects of stuffing in a TH.
It looks like it is missing something....how about we add some perpendicular bracing pieces? They would go from the back panel to the baffle board.
The boxes I'm using now, "pressurize" the 16' x 24' HT room, not all the time, just now and then (at low/moderate listening levels).
I did some checking, the box is about 60 cubic inches bigger, so no concern about volume.
NeoDan, good that you didn't post plans; 15" of forbidding fruit......:scared:
Hi ODougbo,
