Hornresp
Hello David,
Seems OK to me too.
Still the problem of the inverted phase on the phase graph ... (wrap around + and -180° and not around 0°).
Though the calculated impulse response has the correct polarity (could be only a problem with which phase is diplayed: uncrorected or corrected...).
Best regards from Paris
Jean-Michel Le Cléac'h
Hi mimura,
Your design looks okay to me.
Others with more practical experience may wish to comment further.
Kind regards,
David
I have been away from the forums, and the internet, as I relocated from Melbourne to Russell Island in Moreton Bay, Queensland. I got back online on Saturday and find I am unable to connect to David McBean's new link. Well, I think its a new one. I had no problems before. I use windows 7 and Google Chrome but have tried IE well. Is my PC lacking something? I'm looking forward to any help.
jamikl
Posts #2538 and 2540
Hi David,..I just had to ask. Thanks for the explanation and the example, one question though: when setting the Sd in your example to 0.5*Sd do I leave all the other parameters as they were with a single driver?
Hi Oliver,
They will change too in a IMO weird way as BL Rms and Mmd will be UN-recognizable if doing a real world measurement.
b 🙂
Hi jamikl,
The current Hornresp link is Hornresp. The webpage is very kindly hosted by Sabbelbacke in Germany.
I have noticed that file download times have been significantly slower over the past week or so, but I don’t know the reason why.
Do you have a dial-up or a broadband Internet connection?
Kind regards,
David
Seems OK to me too.
Thanks Jean-Michel.
I have no idea why my reply to mimura was posted twice, 28 minutes apart 🙂.
I get the phase response shown below - isn't this correct?
It seems to be wrapped around 0 degrees okay.
Kind regards,
David
Hello David,
Your phase graph is correct.
Here is the one I obtained with the new version of Hornresp downloaded few minutes ago.
Attached is the Hornresp record mimura.txt I used.
Best regards from Paris, France
Thanks Jean-Michel.
Kind regards,
David
  • mimura.txt
    mimura.txt
Hi Jean-Michel,
The reason for the difference in our results is that you are using the 'unmasked resonances' option and I am using the 'masked resonances' option.
I am not sure why this should have such an effect on the phase wrapping process - I need to investigate further 🙂.
Kind regards,
David
Hi David, I'm using ADSL2+. If I wait long enough I get the "Web page is not Available"message. I've been trying for three days now - same result each time. I never had any problems two and a half months ago on the same computer. Don't know what is wrong now.
jamikl
Hello David,
Hello David and all the members.
Thanks for the help. I do not know if it will affect projects that are going to do it. I do not know much about such details.
Thank you for good.
Post #2554 - Isobaric Driver Configuration
Hi David,
I'll attach a screen print of some notes in a spreadsheet. Using these values seems to work well enough. Please, let me know if you find any big mistakes.
Hi bjorno,
I am not sure how to interpret the results you have posted 🙂.
To establish a starting point reference - what are the theoretical parameter values for a single Audiobahn AW1251SE driver?
Thanks.
Kind regards,
David
Hi David,
A starting point reference is single coil DVC TS parameters that can be found here: The submitted picture
b🙂
