NVMOS amplifier
Hello Workhorse Sir
greetings i am a new member of diy audio i would like to make this
amplifier little confused which schematic to refer to i can make a simple pcb for it only
need little guidance please can you help me as this is my first project in electronics ONLY please tell me wich circuit post to follow
warm regards
sameer x1
Sameer,
If this is your first electronics project then i will advice you not to build this one, take something simpler with transistors as your project.
Schematic has been updated to facilitate more devices and better stability and ease in setup. 🙂
Some last minute changes include better positioning for compensation capacitors, some values have been optimized along with part numbers and some additional components have been added.
Kanwar
Thanks a ton sir,
a silly question can more outputs be added to this circuit.If possible how many and what will be the value of gate resistances and' s' resistance.thanks again
You can parallel upto 6 pairs of mosfets. Gate resistors and Source resistors will remain of same value. Only thing you need is to put a 1N4148 diode in anti-parallel to each gate resistor in order to allow fast discharge and thus decreasing cross conduction at HF.
Just making sure, a diode across the 220 ohm gate resistors?
Are the BC546 and 556 a better transistor than the MPSAs?
thanks, sam
BC546/556 have higher gain than MPSAs. I have used MPSAs in cascode form where high voltage level shifting takes place. Regarding gate//diode, see the attached pic for clarification 🙂
