QUASI Amplifier for Beginners
With only 3 wire for connect this VU meter can be add to amplifier, and you have 4 LED display per channel.
Ex-Moderator R.I.P.
Joined 2005
boa tarde aqui é charlestron, do pais Brasil,gostaria de saber se algum membro des forum tem o layout + pcb do aamplifier matrix 1,4 de 1500e 2ohms, meu email é -
Good afternoon here is charlestron, the country Brazil, I wonder if any forum member has the des + pcb layout of the matrix aamplifier of 1.4 1500e 2ohms, my email is -
translated by moderation
:cop:
please post in english
and please do not post/publish private email
there options under you 'personal details', PM(personal mail, only through forum), or email directly
:cop:
moderation
You can use 2SC5200 instead 2N3773, this amp use only NPN outputs.
sorry sir my bad thx for the reply and btw sir if i used 10 pair of output using 47.5-0-47.5 volts how much overall output wattage and sir all of the caps in electrolytic value are all in 80volts or 100volts espicialy for pf and nf thx..
regards
