B1 Buffer Preamp
Cloning the original B1
Has anyone tried to clone the diagrams that Nelson has posted on the PassDIY site ?
If you look carefully there is a discrepancy between the PCB layout and the schematic.
On the schematic C3 is connected between 0V and Vcc/2.
On the PCB one end of C3 is connected to Vcc.
Which one is right ? Should C3 be across C2 or across D1 ?
The plot thickens.
Using a Gerber File Viewer it would appear that Nelson has connected C3 across Vcc to GND.
There also seems to be a few possible places where GROUND loops could occur.
Has anyone got any views about compaing the Aleph P1.7 against the B1.
I've all but given up with the Pumkins. I've got most of the components for either build as a pre for my Aleph 4.
My CD player is almost there with enough drive for the Aleph 4 but not quite.
I like the B1 because of its simplicity.
This weekend I'm going to try the Pumpkins with a single Shuntky. I still cannot get my head around why they sound like "Whooshing", "waves at the beach".
The Whooshing settles down after a while but I still have a minor hum problem. That may be resolved with the single Shuntky.
