The Very Best Amplifier I Have Ever Heard!!!!
You have no knowledge of electronics so your practice does not mean.
If you have knowledge of electronics,you did not draw like that(you say your circuit is right).😉
true or not? You know and I know, and things I actually make things such as layout,
I'm using all the same as the schematic I posted!
The capacity of a connection may not apply to you, but for me, I see it right
Hix,it is in static conditions.
When NPN in bottom saturated,it not so.😀
A42-92 was tested, no matter what happens when using a long time.
please see the FZT857, 957 under My PCB
Designing any To2 device to dissipate a quiescent power of ~50% of Pmax (@Ta=25degC) is completely bonkers.
What will the Tc & Tj be when the amp is relatively cold?
How high will the internal temperature rise in use?
How high will the Tj rise in use?
How will the instantaneous dissipation vary with signal?
How high will Tj rise with signal and operating temperature?
