The Very Best Amplifier I Have Ever Heard!!!!
A stereo amplifier with dual polarity supply rails could have 4 sets of smoothing capacitors, if each amplifier has a separate PSU.
6 paralleled 8m2F would give +-49m2F per channel, resulting in 196m8F. Or as the brochure says approaching 0.2F
Exactly it is 72x100uF = 7.200uF( one mosfet one capacitor) + 4x1.000uF = 11.200uF for output stage(all)
Not included capacitor for Vas,pre,...
If they combined all the capacitors in a machine, I have no idea
Hien,
72><24.
That should alert you that, you have misunderstood something about the data you are reading.
The 72 caps next to the 72 output devices are the decoupling caps. The 100uF quoted also confirms they are likely to be decoupling caps.
The 24 caps are in the power supply.
Hien,
No,in main power supply have not caps,only diode rectifier.
The 4 capacitor of soft star
regrards
quanghao said:
No wrong, and no copy of you!
I practiced many times, to have the same value!
Schematic you gave false and not true reality!
The values ​​given are based on my practice many times, finishing last, but maybe it is just the beginning of the capacity.
You have no knowledge of electronics so your practice does not mean.
If you have knowledge of electronics,you did not draw like that(you say your circuit is right).😉
Have a few problem in circuit.
1. I drew the wrong and that you was copy the wrong to your circuit (see picture)
2. MPSA42/92 not be used with +/-75V in the Vas .
Please see the image, line I is fixed. I = I1 + I2, I1 I2 increases, the reduction should decrease the VCE.
VCE Q29 is inversely proportional to I2 so P = I2.75 = 4.66x75 = 349mW <625mW.
What do you think it??
