MPP
I agree....will post it tomorrow...then we have a chance to sleep on it
Joachim will you do a perfbofeard..or is it tooo complex for that..??
According to the nice sweedish work i belive theres are more options to tha zener...maybe 3 of theese could do a good figure if run at 5 mA
BCX55/C3V9 (0.5W 3.9V):
#1 @ 1mA: 1.7 1.8 1.7 1.6 1.6 uV
#1 @ 5mA: 1.1 1.1 1.1 1.2 1.1 uV
#1 @ 20mA: 0.94 9.76 0.84 0.79 0.77 uV
#2@1mA: 1.6 1.6 1.6 1.5 1.6 uV
#2@5mA: 1.2 1.1 1.1 1.1 1.1 uV
#2 @ 20mA: 0.97 0.78 0.86 0.76 0.77 uV
This is what I have. There seems to be 163MHz 1mV, but with the 'naked' circuit on the table I do think it is environmental. It is less than 1mV, right on the limmit of the scope.
This is where I'am Now..Freeze...
Think that PCB and Perfboard can comence...🙂
Wrong designation on two helper transistors, all should be BC327-337
By the way, that buffer looks awesome...don't know what to call it.. driven diamond cascode..??
michael
There is still a small improvement to be made. R17/R29 can be split in two (2 x 220) and from the center a capacitor could be connected to ground (470/1000uF). I know the power supply is very good, and this is not ‘needed’, but still…
Will add that...and post new schematic later toady.... to be clear I suppose you mean R27 and R 29.. True that takes even more noise out, and reduces the resistor current noise at the same time.. good thinking..! (again)
The C-3-4-8-9 is supposed to be 10mF and 3.3 Uf for decoupling, though the decoupling is not needed on a high impedance current mirror, I can still hear it, and if at Mundorf tinfoil cap is used it add's a pleasant calm warmth to the sound. ( just one of those things you can hear, but not explain)
