Wavebourn Tower-III High-end hybrid amp
Wavebourn, have you ever tried the hydrochloric acid + hydrogen peroxide etching method? It works very well and is very clean, the solution turns a clear green with no sludge.
Did a long time ago when did not have a ferric chloride. Also, "Root Killer" with a kitchen salt 1:1 works well enough. Nitric acid works fast, but it is dangerous.
Novermind, I expect my ferric chloride soon by UPS Ground.
I got it, finally, more than a month after ordering... 2 lbs of a powder, that means 1 gallon of a water. It heats up significantly being dissolved, so I need to pour it slowly into water mixing carefully by some plastic thing... I am going to dissolve all of it at once and keep in a glass container because left in bag remains will absorb water from an air and damage a polyethylene bag.
Enjoy. Since it is public domain already... 🙂
I see the version you post here has a bjt, I have some of your schematics made with fets, but then as I want use a 12ax7 the capacity plays a big role, bjt has less capacity, and are better in the low current triodes.
al the tests I did, differenty are most though the used power mosfets, therefore I go test a compound stage.
In the last breadboard I used 6N1P input loaded on BSP-225 P-type MOSFET, and triode strapped 6P15P loaded on IRF730. Pictures on oscilloscope you could see in this thread belong to this version, except one when I tried 6N2P (close to 12AX7) resulted in too asymmetrical phase distortions on high frequencies than I would accept.
I still did not finish building the prototype...
12ax7 works best in Mu-stage with penthode on top, then sound is very open with details, tube has then enormous headroom because of the high plate impedance with penthode ccs on top.
mosfets works fine with higher current tubes, today I get 6N9C tubes from russia, and earlier 6N2P and 6N1P are coming together with 6AS7.
6P15P are good for a mu stage.
so I can do a polka soon.
Wavebourn,
Referring to the schematic in post1 - why don't you drive the gate of the FET from the emitter of the transistor Q7 for a low impedance drive ?
Do you still favour this output stage design, or do you have a better one (and would you share it) ?
Q7 is a voltage to current converter. Collector current reflects voltage drop change on the plain linear resistor in emitter. If we add there some capacitance, especially non-linear one, can you imagine what happens?
The main idea was, to load a source follower on a counter-modulated current source.
Better ideas? Yes! There was one, when a source follower was bootstrapped by another one. So called "Augmented source follower" loaded on counter-modulated current source. It was real room heated, and I never finished the prototype, it still lives in the corner of my living room. 🙂
Time for the next version, improved... It will be 100W per channel now. BJT CCS, Sic MOSFET augmented source followers. PCBs for output stages.
Wavebourn,
In the spirit of using what is in the parts bin.......Is it possible to achieve good results from this design with all-BJT output. In other words, instead of FET at the output, use a darlington BJT (to ensure sufficiently high impedance load on the driver stage) made from discrete darlington based on 2N3055 for the final power output ?
Actually, I have heatsinks with total of 16 2N3055's literally riveted to the heatsinks - and I only need single channel mono amp. I could use another 2N3055 to augment the follower, and another 2N3055 could be used to regulate the power rail. And leave a few 2N3055 on the heatsink as spares.
How does the SIC mosfets into such amp? have these not a big gate capacitance or other beefy drive needs?.
I did a full platefollower version, people here did like the sound very much, really fast but still soft sound.
regards
