900W H-class PA Amp with Limiter
without load you have high voltage on output .
If offset is normal , install some speaker and test or take oscilloscope and see what happen when led is light ( whit 4 or 8 ohm resistor )
Regards !
I have no oscilloscope, but i noticed that some delay when switching to high rail, also test with speakers load.how to solve & what is the method for set proper offset.
bjt power amp class h
2 L/ CLASS-H
relay connection
hi Chester
greetings first of all THANK for giving diyers another H class amplifier
SUPERB SOUND QUALITY and the assistance you have provided all the way i am really grateful for schematic and great pcb design real good bass crisp highs and
POWER
1 any diyer making this amp please cut nc no connections on pcb of relay otherwise no problem amp came on first time once again thank you chester looking forward to make more amps of yours
warm regards
andrew lebon
is it correct the relay connection?
Dear Apex
Please help about H900
start clipping when high rail triggers, still same condition without load.
I use LED as a clip indicator instead NSL32
transformer 80-45-0-45-80AC
please tell me reasons & solution.
Hi apex sir,
pls can u check this power supply pcb board is correct for h900. i draw from the scematic.
because of the capacitor size, i bought capacitors and not fit to Ur psu baord, so thats why i design this pcb.there are series in caps. 2 into 10000 in series reduced to 5000uf or can u explain.
