diyAB Amp - The "Honey Badger"
That failure could had been easily fixed by adding an aluminum thermal bar across all the outputs.
Yes, but I was stubborn 🙂.
My chosen layout and heat sink height does not give much flexibility with mounting arrangements:
http://www.diyaudio.com/forums/solid-state/192431-class-ab-amp-diyaudio-30.html#post2719715
My only options now are to drill/tap a new set of 13 holes 1/2" away from the current set and live with the asymmetry, or to start again with a fresh
($$$) heat sink.
($$$) heat sink.
That's a nice looking board you got there. Though I'm biased with OS's approach because I love those casings with the heatsinks at the sides ala Krell.
You're right, I hope someday (in our lifetime) heatsink prices drops like a rock... though I doubt it... 😀
Slow day at the office...
matched hfe for the LTP transistors...
applied thermal compound and tied the LTP transistors...
mounted and soldered...
I also did this to the small CCS transistors...
you can also use this "panduit" stainless steel ty-wraps.......Stainless Steel Cable Ties, Permanent Identification
Thanks tony, those things looks real sturdy...
heat shrink tubing also works well here for small signal devices
mlloyd1
thanks, that's a great idea and should really work well too..
Yes, as mlloyd1 pointed out, I would expect heat shrink to work quite well. Superior to cable ties? Perhaps not significantly so.
I'd stick with the cable ties for now, will try the heat shrink tubes in another project though...
Baby steps... It's a holiday today so I got some time to work on the boards...
and some bokeh shots... 🙂
If you are using multiple pairs then the little brother may give adequate cooling/dissipation.
If you are using big brother than a one pair output stage is more feasible.
Excellent point, I might just be wasting Big Brother for this amp if 3 pairs of Baby Brother is more than enough...
That's one point each for Big Brother and Baby Brother then... 😀
