Fast, fun, Inexpensive OB project
Some additional thoughts on the L2 trap inductor
A quick additional follow up on the trap inductor, L2.
The 19 ga. Pano called out in his Bill of Materials (BOM) can work. It has the obvious advantages of lower cost and size. However, with it's higher resistance of about 0.9 ohms, an adjustment in the R2 pad resistor would be required to retain the tonal balance of the system as well as the desired Vifa crossover high pass slope. R2 would drop to around 3.5 to 4 ohms to compensate for the higher L2 resistance.
Per standard theory, the higher resistance could slightly degrade the Vifa's performance, but from a practical standpoint, I wouldn't worry too much about it. Just my $0.02 worth.
The true efficiency of the current version of the SLS is about 89 DBW. Add in cross over losses and a bit of power compression (it is a long throw woofer) and then add back in the 6 db when operating a pair of them in electrical parallel, and you end up around 93 dbw. This set up would result in a 4.7 ohm load. Not as SET friendly as a single 8 ohm 18".
So, you could use a parallel pair of SLS's, padding the Seas 8" to match. This assumes a third order electrical crossover on the SLS and other crossover tricks. 20" wide baffle and so on.
A single 18 with an Xmax around 6 MM peak will have very little power compression and should be able to provide a true 97 db or better efficiency like the discontinued Eminence woofer I currently use in the HE prototype.
Thanks for the summation John. Spending a total of $40 more for the low dcr inductors might not be in keeping with the "inexpensive" part of the project.
Ahh. alright, I see. Good luck with your search. always exciting too se how "simple&good" these sets turn out🙂
BTW, how would the vifa driver handle 2sls`s?
The Vifa is about 84 or so DBW up in the freq range we use it. Add the 6 db rear radiation and allow for trap and rear reflection losses and you end up around 88.5 or so usable before we pad it to match the single SLS. This is well short of what the 2 SLS running in Electrical parallel will provide per my prevous post.
The Seas 8" FR is around 94.5 dbw plus 6 db rear radiation less it's trap & reflective losses, so it could work with dual SLS or the efficient 18" with the proper pad and crossover.
All of these efficiency values are quasi 1/2 space.
I'm wondering if I really need to go with the HE design...
My room is fairly small and I am using an Eico HF-81 (around 15 watts). I don't know if this would be enough power for the standard Manzanita or not. If not, would a 30wpc Sansui 1000A do the trick?
Manzanita power requirements
This has been a curious topic from the beginning. Most of the time these days I drive the Manzanita with a KT88 SET that I operate in Pentode mode. About 12 - 15 watts max per channel.
Assuming the baffle face is 40 inches or so from the rear wall, 8 - 10 foot listening distance and general musical formats, the Manzanita is quite good. If you really want to rock, you can hit the Manzanita with 100 + watts and it will respond accordingly. A pair can deliver 100+ db peak clean output down to about 40 Hz.
Many people have listen to it driven with a 8 watt "T" amp during some of my LSAF and RMAF demonstrations and have found it surprisingly listenable with that limited of power.
As usual, it gets back to personal need. And how you listen to, and what you listen to music wise.
Just for the record (no pun intended), 15 honest watts per channel will support an upper 80 db output level at 8 feet with a 6 db head room on most music in a small to medium residental environment. For a majority of users, this should be adequate.
Thanks John, that is very enlightening🙂 I guess I had it stuck in my head from earlier in the thread that the standard Manzanita really sucked up the juice. I built the original version but I had a higher power class D amp at the time.
Agree with John. The original Manzantia will do OK at modest levels with low power. But to really rock out, you need power. 60 WPC was plenty for me in a small room. More would be better.
These are down in Magnapan sensitivity territory.
That Pano guy, you got to watch him every Minute!!
The amp in question is an ASL 15 DT.
ANTIQUE SOUNDLAB
This particular amp was purchased for use at LSAF in June, but, unfortunately had some problems.
So, off to that Pano guy for evaluation and repair after the supplier, Divertech could not seem to find the problem.
After a couple of part upgrades and god only knows what else Pano did, the thing now sings like it should.
As for the efficiency of the Manzanita as currently configured. It is still an inefficient speaker. Low to mid 80's DBW. Of course the dirty little secrete is that a surprising number of small two way closed box systems with similar bass extention are not any more efficient and when you try to power most of them to the levels the Manzanita will play at, they, well, just can't keep up.
A good inexpensive little amp solution would be the PE (Dayton) 50 WPC "T" amp. Dayton Audio DTA-100a Class-T Digital Amplifier 50 WPC Provides Power To Computer Speakers, Bookshelf Speakers, Headphones, And More! 300-383
Not a world beater by any means, nore is it close to the musical ability of the ASL, but for an inexpensive throw down amp to get on started, it's not all that bad. Delivers around 35 WPC in to 8 ohms which is enought to get the Manzanita going.
I'm lurking quietly waiting for the new high efficiency design :trapper:
Can anyone post a link to details of the old (high efficiency) design ?
I'd like to see about "borrowing" some ideas to experiment with the design of my current open baffles which use vintage drivers
afaik no high efficiency design has been posted yet. John is working on trying to find a current production 18" woofer that works well.
