LJM Audio
AC TO DC
MUR8100E * 4
63 V2200UF * 8
For reference.
56W or 56V.. if it's 56 Watts.. it won't do the job for either. I'm looking at 300 - 500 Watt SMPS for use with the L15D
If it's 56V, then the L15D is the choice, 55V is the recommended voltage in a 45-60v range
The L20D has a range of 60-80 with a recommended of 70V
ljm_ljm
Do you have a PSRR measurment for the L15D? I'm thinking about using a SMPS Power supply from Connexelectronics like the SMPS500QR..
You are going to use a switch power supply, switching power supply I used in the L15D, and L15DX2 above
(IRAUDAMP7S-150).
They are all very good work, and my client installed in the L15D car above. Use a
DC12 > +-50 V switching power supply.
As long as you change the voltage of power supply is less than 10 V +-basically do not have too big effect.
Hi ljm_ljm,
do you have any plan to produce lower wattage version with IRFI4024H-117P and IRFI4212H-117P output device? the version with IRFI4024H-117P would be interesting since it could be potentially powered with 2 x 12V SLA battery.
I see, so if I change the resistance in accordance to MrSlim pointing on page 37, I basically could turn down the power requirement (and gain as well?), while still using the IRFI4019 output device?
Do I need to change the zener and the clamping diode too?
I've noticed that the l25 version is available on ebay. Will you ever release the l10 with IRFI4212H? It could be the best choice of who is not fully satisfied with his t-amp power 😀
Do these amps also support balanced connection?
