DC Servo MOSFET Amplifier
Fan can be activated with this circuit if there is signal present on amp outputs.
Hi Apex!I use a similar topology.The soundis very nice.But about you ramp, I learned only today. Ishowed your diagram.Why do you use IS servos, alongwith a capacitor C6. C6 is not required if there is a servo. Or the servo is not necessary,if there is a C6?
Abaut HH like F100
yes sir? (M900) .. and I drew back from HH vx450/650 with version 4set sk135 mosfet. I have burned on botom pcb of HH vx900. and I plan on turning it on again. I seem to see any similarities in the scheme of Hitachi F100. if the path is correct pcb, I will soon be printed along with the F100 MK2.
regards..😛😛
