The new Bodzio Ultimate Equalizer program might be the magic set up for crossover and phase linearization of these coax drivers.
Trying to get it for a week or so now - seems UE (Bodzio Ultimate Equalizer) is kinda unobtainable.
("The new UE-PC V2 is due to come out soon")
The UE stand alone preliminary version has expired at January and you have bad luck when not been informed.
Regarding the UE version coming along with SoundEasy I await additional information if and to which price I can upgrade from ver1.6 that I bought few month before ver 1.7 containing UE came out...
Michael
PS
continue using "Acourate" in the meantime
http://www.acourate.com/
Was there ever a Ver1.6? Even of there were, it would have been a decade ago. When was Ver1.7 released? If it ever were, it would probably also been about a decade ago.
ver 16 / 17
Not yet - need quality 2" driver.
Don't we all 😉
Do you have the impedance curve of the Radian 950??
That's the style of horn mostly associated with
Guigue in France, I think.
He used to make those,
I don't know if he is still in business.
Quite a long window for the CSD. 1.8 seconds. Don't people mostly use something like 3ms?Not yet - need quality 2" driver.
Below JMLC-350 with Radian 950PB and Truextent diaphragm.
Is it possible to find somewhere a JIG in order to build this kind of horn ?
Penia
Horn Mouth
Hi guys ... what would I loose in quality by terminating the Le Cléac'h mouth as it reaches 90 deg instead of rolling back over? May have been covered. I can only turn a 19" horn and would like a lower Fc than 450hz with 2" throat. Thanks, Zene
Most likely you will introduce reflexions back to the throat and directivity pattern will be less smooth.
Thanks jzagaja for the graph. Big difference. Lesson learned. I will not screw up Jeans' work.
Zene
Zene
Hello,
A printable version of the Powerpoint document corresponding to the illustrations of the conference I gave in december at ETF'2010 about horns is downloadable until May 3rd at:
https://filex.mines-paristech.fr/get?k=1nHabEar3H3Wk0oh7Ab
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hello,
The pdf version (Acrobat) of the document corresponding to the illustrations of the conference I gave in december at ETF'2010 about horns is downloadable until May 3rd at:
https://filex.mines-paristech.fr/get?k=j3u3ik9ZUwL2zRTYub5
- Jean Michel on LeCleac'h horns
