Could this circuit be adapted to run on 65 V high rail and 35 V medium rail? I f yes, which are the components to re-calculate?
Can this circuit go as low as 2 Ohm with such 5 pairs?
effebi
effebi
effebi
Use 1k2/2W instead 2k2/2W from MV to 15V zeners, and you can use 2R load with this rail.
If you refer to the resistor at 3.3K /1 W in post #116, that sounds ok, only for setting the correct bias current into the zener. Otherwise please tell me whis is the last/correct schematic.Use 1k2/2W instead 2k2/2W from MV to 15V zeners, and you can use 2R load with this rail.
Anyway, thanks a lot !😀😀😀
Your schematic is GREAT and I am going to use the output stage connected to something like a LME49810 as a VAS to make a sturdy rugged PA!
effebi
effebi
You can use separate +/-15V PSU (from protect board) and drop out resistors and zeners, in that case no need to set bias current for zeners with different rail voltages.
hi apex,
any pointers for me.what else i should do.
nothing seems to be wrong.i have tried connecting it directly
to ac mains as well.nothing goes wrong everthing normal
but my dc voltages sags from 60 to 22 and -60 to -14.
thanks
ravs
be a vegeterian....
thanks
ravs
be a vegeterian....
hi apex,
thanks
ravs
be a vegeterian....
Rail voltage drop with useing serial bulb in primary is normal if current rise.
hi apex
even without a bulb.directly connected to ac mains.
ravs
be a vegeterian.....
hi apex
ravs
For high voltage drop there must be high resistance in the circuit. Test your PSU without amp.
pls give me a layout of H900.. please
SEnd to my email.. dj_rh0meo@yahoo.com thank you..
hello sir...
i use 18 X 18 vac for h 900 protect .
bt when fan on full speed
i have only 19vdc on fan pls help me for this..
thank u sir....
thank u sir....
hello sir...
thank u sir....
What is power of 2x18 vac transformer, what is voltage on 1000uF/35V cap?
PSU schematic and pcb.
Apex-
Very nice of you to support so many builders!
The PSU has the voltages calculated wrong. before any other diodes and parts, the AC/DC will only BR to 112 and 56 - not 120 and 60...
BR = AC X 1.4 at 100% efficiency not X 1.5....
Silver,BR = AC X 1.4 at 100% efficiency not X 1.5....
A transformer does not give out a fixed voltage.
The secondary Vac depends on the mains supply voltage (primary Vac) and on the load current Iac.
The DC voltage from the PSU is not a fixed value, it wanders all over the place.
We can measure the worst case highest zero current PSU voltage. We and you will now know what the highest DC voltage you can ever get from the PSU.
Work down from that highest to find typical DC voltages.
hi apex,
i tried your darlington topology.and guess what everything was ok no abnormal
readings.no sagging of voltages. dc offset of 2mv.same reading on every collector.
then i switched back to normal driver stage with mje15032/33 .switched on
2.1mv dc offset.no voltage sagging everything normal.then i saw i forget to add
22ohm resistor which was connected to both emmiters of mje15032/33.as i
connect then every thing messes up.30 mv dc offset.voltages sags 60 to 38
and-60 to-14.different reading on every collector.what should i do.
thanks
ravs
thanks
ravs
6th H900
ready for mounting 6th 2 channel H900
Thanx to Miles
Thanx to Miles
hello sir
i use triple ef stage vd 4 pairs...is that ok?vd triple ef stage what will happn??
thank u sir....
thank u sir....
Thanx to Miles
Great progres, I hope this will be succesfull build,
hello sir
thank u sir....
It's OK, bias must be readjust.
- 900W H-class PA Amp with Limiter
