100W Ultimate Fidelity Amplifier
just to confirm... the blue circle... is it 100p according to the schematic or 22p according to PCB layout?
AX-14 Schematic
Hi Apex,
I need your help.
1. I want to get 300 watts rms @ 4 ohms from ax-14, do you have pcb diag for that.
What protection circuit to be used, please give block diagram with connections.
2. I want to use pre amp with multi inputs with remote for selecting channels and other controls such as , volume, bass, treble. Can you help with it.
3.also which is more better bridging two amp boards gives better results, or paralleling
transistors, does it have any difference in audio quality.
Hi Apex,
I need your help.
You can build D-14 or go to thread http://www.diyaudio.com/forums/solid-state/162043-mosfet-amplifier-irfp240-irfp9240.html
irf trannies are not available at the place where i stay.2sk1530-2sj1201 are very costly they cost 22$ a pair here. Where as 2sc2922-2sa1216 are available for 8$ . so amps based on these are which i would like. can d-14 be used with sanken trannies-2sc2922.
please post pcb of d-14
Also is there any difference in output or sound quality when we use 2sc2922 -2sa1216 in place of 2sc5200.
I have built two tower speakers, Each has 2 peerless 8" Drivers and tweeter in mtm design, both are rated 250 Watts rms at 8ohms, I have made a 3 way crossover. I have to power these monsters.
Transistors are very costly as , they are not easily available and i have to travel 60 kms to get them.
aNy other transistors that can work , but may be a bit cheap as i dont want to compromise on sound quality.
Sorry i am asking lots of things.
D-14 use darlingtons, 2SA1216/2SC2922 (if not fake) can be use for B500.
