Pictures of your diy Pass amplifier
Here is my Balanced F4, I drive a pair of them with a Pumpkin and Impasse the Pumpkin is faster the Impasse is laid back. I have been holding on to a set of SIC JFETS waiting to build J2 clone if it ever comes out, and would like a build a B4 and a pair of OB. Since Mr Pass seems to be holding those designs close to his chest I have had to resort to brewing beer. The wife is much more prettier and the sound system sounds pretty good.
Bill
I have been thinking of upgrading the caps to Simlic II if I do I will shoot some inside shots. I used an unusual method of clamping the output fets so I could change boards conveniently. It is a little under sized on heatsink but I like em hot. If I ever finish the control section of the pumpkin I will put the Impass up for sale.
Bill
Hi Guys
I just completed F5 for a friend of mine.. I'm using Fairchild for outputs and without the thermistor.. it takes about 30mins for the bias to fully set..
Nuvotem 225VA and 4 x 27000uf/25V caps per channel.. DC offset is about 1-2mv.
Thanks NP..
regards from the Philippines.
You guys are building some nice stuff on this page.
You will want the B5 for that OB, and there will be a
diy description of the filters, so you will be able to roll your
own.
"You will want the B5 for that OB, and there will be a
own."
Sweet !Yes I am B challenged, I was holding on to a set of f5 boards for the bottom end. Mr Pass was playing with some OB designs was anything published?
Bill
