Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!
Uncle Carlos and Andrew T
Thank you for the suggestions.
It seems the problem was cold solder joint
I resolder everything.. remeasured dc offset .... -0.6 mV and 2.3 mV
I'll test the amp with a 8R dummy load
Happy New Year to all.
Wishing you all the very best
The supply...some pictures
Mine was modified.... first reason is for test purposes..second reason is that i have not some parts.
ahahahahah!
regards,
Carlos
Output coil..... i have made tests with a different output coil and resulted good
Internal diameter - 5 milimeters
External diameter - 7 milimeters
Wire diameter - 1 milimeter
Coil length - 17 milimeters
Number of turns - 15 plus half and plus half...this represents 16 turns
Inductance - aproximatelly 0.692 microhenries (692 nanohenries)
Resistance in paralel was increased to 15 ohms, 18 ohms or 20 ohms / 5 watts... can be a coiled wire resistance.
During tests i have used the coiled wire resistance of 18 ohms and 5 watts...some inductance is provided by the resistance windings.
Blue boards have holes into the coil position, that accept 1 milimeter coil wire without problems.
regards,
Carlos
