Complete Novice Needs Help
Now for the really stupid Question ....
Zener diodes have a black end and a red end ... am I correct in believing that the black end is to be soldered so the white line on the PCB is beneath the black ... ?
This is possibly the dumbest question ,but I have never been told or read about this.
Please advise ... this is my third set of boards HELP
thanks , Rich
the symbol for a diode is a triangle and a bar across the tip.
The arrow of the triangle points in the direction of conventional current flow.
The bar matches the black bar on the device.
If you want current to flow and for the diode to drop Vf then the triangle points to negative.
If you want to block current flow then the triangle points to the positive.
The black bar on the PCB is the same black bar as on the symbol, which is also the same black bar on the device.
Thank You
Hi Andrew,
thank for that ....
Ric ,
that afternoon you have offered is a must ... I took 8 hours to solder one board, being careful not to burn solder ,cleaning the tip before each joint , checking the values twice ,only having one value on the bench at any one time , the once over with a magnifying glass.
I dont understand the grounding ... I measure the DC across speaker outs and get - 2.760 vdc without ground the amp board to the chassis. When I connect ground I get 28.07 vdc .
Im not going to give up . Im looking around for beginners courses on the web. Im going to be off work for another year at least and this seems like a worthy endeavour .
Its kind of like try to un-ravel a ball of fishing line washed up on the beach .
Finding the starting point is the key ....😕
Rich
So , in reply to your offer .... YES PLEASE ..
Congratulations
Have you checked the output offset after about 1 hour operation ?
If not do it because it can change with the mosfet temperature.
You can fine tune the offset current on your right channel (check the schematic for that).
Why are your readings negative (-10.2mV and -101.4mV )?
Ric
Hi Ric,
the offset is leveling out ...
L = 44. 7 R = 66.7 , both + vdc
Right 500r trimmer wont go any higher . I was advised to get more heat into the Fets .. What the 100k trimmer for ?
R
Ps I have ordered new trimmers !
Hi Hannes ,
it really does sound good . The best upgrade,after the Be Diaphrams ....
thanks for your help with the fets .....
Rich
Hi Ric,
R
To help you with that you have to tell me what diagram/schematic you used because on the original Aleph 30 schematic the change is done replacing 2 resistors (1 for the offset and 1 for the idle current).
Ric
